We compared five Mac disk recovery tools using deleted folders, a quick-formatted APFS image, plus mixed photo, video, document, plus archive files. Disk Drill offered the clearest balance of recovery controls, previews, plus everyday usability.
Best for: Mac owners who want a guided recovery workflow for deleted files, formatted drives, SD cards, or unreadable external disks
Best for: IT staff or experienced users who need granular scan controls, RAID reconstruction, network recovery, or a hex editor
Best for: Users who need to image a troublesome external drive before attempting logical recovery
The five apps below are compared on APFS file-system support, built-in disk imaging, license cost, plus overall usability. Scores reflect editorial judgment from the test workflow described below, not a controlled laboratory recovery-rate benchmark.
| Tool | APFS Recovery | Disk Imaging | Price | Score |
| 1.Disk Drill PICK | ● Yes | ● Yes | $89/yr | 9.2/10 |
| 2.R-Studio for Mac | ● Yes | ● Yes | $79.99 one-time | 8.8/10 |
| 3.UFS Explorer Standard Recovery | ● Yes | ● Yes | $69.95 one-time | 8.6/10 |
| 4.DMDE | ● Yes | ● Yes | $48 one-time | 8.2/10 |
| 5.PhotoRec | ● No | ● No | Free | 7.6/10 |
Disk Drill gave us the cleanest route from drive selection to file export. On our 64 GB APFS test image, it rebuilt the original folder tree after a quick format, then separated deleted, reconstructed, plus existing files so the results did not feel like one giant pile.
Previews opened correctly for our intact JPEG, PDF, DOCX, MP4, plus ZIP samples. Recovery-chance labels were especially useful when duplicate filenames appeared. The byte-to-byte backup feature also let us work from an image instead of repeatedly scanning the source disk.
The free Mac edition is mainly a scan-plus-preview tool. Actual file restoration generally needs PRO, currently offered as an $89 yearly license or a $149 lifetime license. That cost is easier to accept after confirming the needed files are previewable.
Best forMac owners who want a guided recovery workflow for deleted files, formatted drives, SD cards, or unreadable external disks
R-Studio exposed far more scan settings than Disk Drill. It identified the APFS volume in our test image, preserved the usable directory structure, plus let us inspect sectors through its hex viewer. The scan results were detailed, though the volume tree took longer to understand.
Its biggest advantage appeared during a simulated damaged-partition test. We could adjust file-system parameters, save scan information, create an image, then reopen that image without rescanning the original media. Support for standard plus custom RAID layouts makes it a serious option beyond ordinary USB-drive recovery.
The demo can scan plus preview, though saving larger files requires a license. R-Studio for Mac starts at $79.99, which is fair for its depth but less inviting if you only need to restore a few vacation photos.
Best forIT staff or experienced users who need granular scan controls, RAID reconstruction, network recovery, or a hex editor
UFS Explorer took a cautious approach to our test media. Its imaging controls allowed skipped blocks, retry passes, plus a map of unreadable areas. That matters more than a pretty results screen when a hard disk is slow, disconnecting, or producing read errors.
On the formatted APFS image, the software found the old volume, displayed its folder structure, plus previewed our intact photo, document, plus video samples. Results were accurate enough to shortlist files before buying, though the interface used storage terminology that may confuse casual Mac users.
The trial provides unrestricted scanning, previewing, plus imaging. It only saves files up to 256 KB. A personal macOS license costs $69.95 as a perpetual purchase with 360 days of updates.
Best forUsers who need to image a troublesome external drive before attempting logical recovery
DMDE found the deleted test folder quickly once we selected the correct APFS volume. It preserved filenames for file-system records that remained intact, plus its raw view made it possible to inspect partitions without hiding technical details behind a simplified wizard.
The tradeoff is usability. Drive names, found volumes, scan results, plus reconstruction choices appear in dense windows. We needed more care here than with the top three tools, especially when separating the current volume from older detected variants.
Its free edition is unusually practical. It can restore up to 4,000 files from a chosen directory per request. The $48 Standard license is perpetual for one operating-system family, making DMDE the cheapest paid option in this ranking.
Best forPatient, technically comfortable users who want inexpensive recovery plus low-level partition tools
PhotoRec recovered recognizable JPEG, PDF, ZIP, plus MP4 samples from our reformatted image without needing the old APFS directory structure. Since it searches for file signatures, it remained useful after file-system metadata was no longer dependable.
The result was messy. Recovered files arrived with generated names in numbered folders, plus several fragmented samples could not be reconstructed correctly. There was no polished preview browser for sorting thousands of findings before export.
PhotoRec costs $0, is open source, plus runs on macOS. It is a solid final pass when commercial tools fail, though organizing the output may take longer than the recovery itself.
Best forUsers who care more about recovering file contents than preserving original names or folder locations
Each tool was reviewed on a Mac using a 64 GB APFS disk image plus a separate exFAT image representing a camera card. The test set contained JPEG plus RAW photos, MP4 video, PDF files, DOCX documents, ZIP archives, plus nested folders. We deleted one group normally, quick-formatted a copy, then removed partition metadata from another copy.
We checked whether each app detected the prior volume, preserved filenames plus folders, previewed intact files, created a sector-level image, saved scan sessions, plus explained its free-edition limits. Scores also account for pricing, Apple silicon support, interface clarity, plus the risk of a user selecting the wrong source or destination.
Match the program to the failure. A normally deleted folder on an external SSD needs good APFS reconstruction plus previews. A reformatted SD card may respond better to signature carving. A slow hard drive with read errors needs imaging controls before a full scan.
Run the free scan before buying. Open several important files through the preview tool, not only thumbnails. If previews are corrupt, a paid license will not magically repair them. Also confirm that the license covers macOS, since several vendors sell platform-specific editions.
Do not install the app onto the affected disk, download files to it, run First Aid repeatedly, or restore recovered items back to that same device. Every write can overwrite deleted data. Internal Apple SSDs pose another problem because TRIM may clear deleted blocks quickly, leaving no content for software to recover.
A clicking, beeping, disconnecting, or extremely slow drive is not a normal software case. Repeated deep scans can stress failing hardware. If the files are irreplaceable, stop testing apps, unplug the device, plus ask a reputable lab for an evaluation.
Disk Drill earns first place because it turns a stressful recovery job into a readable series of choices without stripping away useful controls. Its file previews, APFS support, recovery estimates, plus byte-to-byte imaging make it suitable for most accidental deletions or formatted external drives.
Choose R-Studio for complex RAID, remote, or technical work. UFS Explorer is the safer fit for imaging an unstable disk, DMDE offers strong value for experienced users, while PhotoRec remains useful when the budget is zero or the file system is beyond reconstruction.
Install recovery software on a different disk, create an image when possible, then save every recovered file to separate storage rather than the source device.
