Mac Storage Shortlist
5 Best Disk Repair Software for Mac in 2026
The best choice depends on what needs saving: the files, the filesystem, or your confidence in the hardware. This shortlist separates those jobs instead of treating every disk utility as a repair app.
⚡ TL;DR · Quick Answer
Disk Drill is our overall pick for recovery before repair, thanks to its imaging tools plus file-recovery workflow. For actual filesystem repair after backing up, Disk Utility is the first option to try. These are complementary jobs, not interchangeable capabilities. Disk Drill features · Apple's First Aid guidance.
★ Best overall
Disk Drill
9.0/10
Best for: Mac owners who need to rescue files before attempting disk repair
  • Free byte-to-byte backup tools
  • File previews before a recovery purchase
  • Useful fit for a recovery-first approach
  • Lifetime purchase option
2
Disk Utility
8.9/10
Best for: Mac owners with a backup who need to address filesystem errors
  • Included with macOS
  • No separate license
  • Accessible from macOS Recovery
  • Apple provides a clear repair sequence
3
DiskWarrior
8.2/10
Best for: Owners of older Mac OS Extended archive drives with directory damage
  • Focused HFS+ directory rebuilding
  • Preview before directory replacement
  • Useful niche for older archive disks
  • Clear filesystem eligibility documentation
Five Mac Disk Repair Tools Compared
Compare the job each tool performs, its main limitation, plus the verified price. Scores are editorial judgments about usefulness in a recovery-first Mac workflow, not measured repair success rates. DiskWarrior's listed price is an existing-owner upgrade only.
Tool Primary Job Main Limitation Price Score
1.Disk Drill PICK File recovery / imaging Not filesystem repair $89/yr 9.0/10
2.Disk Utility Filesystem repair No file undelete Free 8.9/10
3.DiskWarrior HFS+ directory rebuild No APFS rebuild $59.95 upgrade 8.2/10
4.TestDisk Partition recovery Technical write operations Free 8.0/10
5.DriveDx Hardware health monitoring Diagnostics only $19.99 one-time 7.8/10
The 5 Best Mac Disk Repair Tools Reviewed
Disk Drill
macOS / CleverFiles
9.0/10
Disk Drill takes first place for a recovery-first workflow, not because it fixes every disk error. Its free tools include byte-to-byte backup, while its recovery features help retrieve files from readable storage. That makes it our preferred starting point when the missing files matter more than getting the original volume mounted again. CleverFiles documents these features.
The distinction matters: recovering files is not the same as repairing their source filesystem. PRO costs $89 per year or $149 for a lifetime license. Start with previews rather than buying on the assumption that every missing document is recoverable. Official PRO pricing.
Best forMac owners who need to rescue files before attempting disk repair
Standout featureByte-to-byte imaging puts a recovery copy ahead of repair attempts
  • Not a substitute for filesystem repair
  • Ordinary Mac file recovery requires PRO
  • Annual plan renews automatically
Basic $0 Scan, preview, plus free disk tools. Pay for ordinary lost-file recovery on Mac.
PRO Annual $89/yr Recurring annual subscription.
PRO Lifetime $149 One-time license with future upgrades. Official pricing linked above.
Recommended Data Recovery Software ↗ Download Disk Drill
Disk Utility
macOS / Apple
8.9/10
If your files are backed up, Disk Utility is the most sensible first repair attempt. Apple's First Aid checks formatting or directory problems without a separate software purchase. It costs $0 beyond the Mac you already own. Apple's repair instructions explain the supported workflow.
For startup-disk repairs, open it from macOS Recovery. Don't jump straight to Erase after a failed repair if you still need files from the disk. First Aid is a repair tool, not a promise that damaged files will become readable.
Best forMac owners with a backup who need to address filesystem errors
Standout featureFirst Aid is available directly from macOS Recovery
Disk Utility Pros
Disk Utility Cons
  • Cannot resolve every disk error
  • No deleted-file recovery workflow
Included Utility $0 Included with macOS. No paid repair tier.
Visit Apple
DiskWarrior
macOS / Alsoft
8.2/10
DiskWarrior has a specific job: rebuilding damaged directories on supported Mac-formatted storage. Its preview lets you inspect the proposed result before committing a replacement. For an older HFS+ archive disk, that is a meaningful distinction from ordinary deleted-file recovery. Alsoft explains the directory-rebuild process.
Do not buy it for APFS repair. Alsoft explicitly says DiskWarrior 5.3 cannot rebuild APFS volumes. The verified $59.95 price below is an upgrade for existing owners, not a new license. The new-copy checkout returned an error during research, so no unverified new-license price is listed. Check Alsoft's eligibility details.
Best forOwners of older Mac OS Extended archive drives with directory damage
Standout featurePreview a rebuilt directory before replacing the original
DiskWarrior Pros
DiskWarrior Cons
  • No APFS volume repair
  • No free trial
  • Cannot recover deleted files
Existing-Owner Upgrade $59.95 Upgrade from an earlier version, plus shipping. Not a new license. New-copy pricing could not be verified.
Get DiskWarrior
TestDisk
macOS / CGSecurity
8.0/10
TestDisk belongs here for partition-table problems, not as a universal Mac repair button. The project documents lost-partition recovery plus specific FAT or NTFS repair operations. The software is open source with a $0 license price. Its capability list is worth reading before touching a disk.
Finding an APFS partition does not mean rebuilding its internal filesystem. Treat those as different tasks. Our recommendation is to use TestDisk only when you can explain the proposed change before writing it, preferably after preserving a copy of the source.
Best forExperienced users investigating a missing partition
Standout featureFree partition-table recovery with filesystem-specific repair options
TestDisk Pros
  • No license cost
  • Open-source project
  • Targets lost partition information
  • Detailed technical documentation
TestDisk Cons
  • Technical workflow takes care
  • Wrong write operations can complicate recovery
  • Not a general APFS filesystem rebuilder
Open Source $0 Free software with no paid recovery unlock.
Explore TestDisk
DriveDx
macOS / BinaryFruit
7.8/10
DriveDx answers a different question: is the storage hardware showing warning signs? It reports indicators such as SSD wear, pending sectors, or I/O errors. That earns it a supporting place in this list, not a claim that it repairs damaged storage. BinaryFruit describes its diagnostic features.
The personal license was listed at $19.99 on promotion during research, covering up to 3 personal computers for noncommercial use. Choose it for ongoing visibility, not to retrieve a missing folder or rebuild a volume. Official license terms.
Best forMac owners deciding whether a suspect drive should be retired
Standout featureDetailed health indicators rather than a simple disk-status label
DriveDx Pros
  • Detailed hardware health indicators
  • Background monitoring
  • Email reporting
  • Personal license covers three computers
DriveDx Cons
  • Does not repair filesystems
  • Does not recover deleted files
  • Personal license excludes commercial use
Personal License $19.99 Listed promotional price, normally $24.99. Up to three personal computers, noncommercial use.
Try DriveDx
How We Evaluated These Mac Disk Repair Tools
This is a documentation-based comparison, not a hands-on benchmark. We checked official feature descriptions, repair limitations, licensing pages, plus Apple's repair instructions. No drives were tested, so there are no invented recovery percentages, scan times, or successful-repair counts.
Scores reflect our editorial preference for preserving data, matching the tool to the fault, making limitations clear, plus keeping costs reasonable. Product facts are linked in each review. The ranking favors a recovery-first situation, which explains why Disk Drill appears above the actual filesystem-repair utility.
How to Choose Mac Disk Repair Software by the Actual Problem
Start with the outcome you need. Missing files call for a recovery assessment. Filesystem errors on backed-up storage call for repair. Hardware warnings call for a replacement decision. The product reviews above identify which job each app performs.
Check the format before paying. DiskWarrior's APFS restriction is a particularly easy detail to miss if you remember using it on an older Mac. Running on a newer Mac does not mean it can rebuild every disk attached to that Mac. Alsoft's filesystem restrictions.
Mac Disk Repair Mistakes That Complicate Recovery
Don't mistake Erase for a stronger version of First Aid. Apple's instructions recommend having a current backup before repair. If the disk still holds your only copy, pause before following a formatting recommendation. Apple's repair precautions.
Our practical rule is to change one thing at a time. Save the error message, note the tool used, then decide what the result actually tells you. Running every utility on this list is not a repair plan.
Choosing a Mac Disk Tool Without Risking Your Files
Disk Drill earns our top recommendation for the recovery-first approach used in this comparison. If you already have a good backup, start with Disk Utility instead of buying another app. Treat the remaining picks as targeted options, not increasingly powerful steps on a repair ladder.
Before choosing a tool, write down the drive's format, the exact error, plus whether your important files exist in a separate backup.
Mac Disk Repair Questions Before You Start
What is the best disk repair software for Mac in 2026?
Our recovery-first pick is Disk Drill. For filesystem repair on backed-up storage, our first choice is Disk Utility. The ranking deliberately separates preserving files from repairing their original volume.
Does Disk Drill actually repair a disk?
Its role here is file recovery plus imaging, not general filesystem repair. See the official feature description before choosing it for a specific fault.
Is Disk Drill free on Mac?
Scanning, previews, plus several disk tools are free. Ordinary lost-file recovery requires PRO. Check the Mac edition's features.
How much does Disk Drill PRO cost?
The official page lists $89 per year or $149 for a lifetime license. The annual option renews automatically. View PRO pricing.
Which free Mac disk repair tool should I try first?
We recommend Disk Utility once your files are backed up. It is Apple's built-in option for formatting or directory errors. Read Apple's instructions.
Should I run First Aid before recovering files?
Apple advises having a current backup first. If important files are inaccessible with no backup, our recommendation is to assess recovery before attempting repairs. Read the backup precaution.
Can First Aid repair the startup disk?
Apple directs users to open Disk Utility from macOS Recovery for startup-disk repair. Follow the startup-disk instructions.
Does DiskWarrior repair APFS?
No. Alsoft explicitly states that DiskWarrior 5.3 cannot rebuild APFS volumes. See the current restriction.
When is DiskWarrior worth considering?
Consider it for directory damage on supported HFS+ storage, particularly older archive drives. Check eligibility before purchasing. Read the requirements.
Can DiskWarrior restore deleted files?
No. Alsoft distinguishes directory rebuilding from recovering deleted files or reformatted drives. See its recovery limitations.
Is the listed DiskWarrior price for a new license?
No. $59.95 is the verified earlier-version upgrade price, plus shipping. We could not verify a new-copy checkout price. See upgrade pricing.
Does DiskWarrior offer a free trial?
No. Alsoft's FAQ says there is no free trial. Confirm the filesystem match before purchasing. Read the presale FAQ.
What does TestDisk do?
It targets lost partitions, partition-table faults, plus certain filesystem-specific repair operations. It is free software. Read the capability list.
Can TestDisk detect a lost APFS partition?
Its documentation lists APFS among detectable lost partition types. That is not a claim of full APFS filesystem rebuilding. Check supported partition types.
Is TestDisk a good first tool for a beginner?
We would not make it the default. Use it when the problem specifically points to partition information, with enough understanding to review a proposed write operation.
Does DriveDx repair bad sectors?
No. Its role is monitoring hardware health indicators, including sector-related warnings, rather than repairing physical media. Read its diagnostic scope.
What does the DriveDx personal license cover?
The $19.99 promotional personal license covers up to three personal computers for noncommercial use. Check license conditions.
What if the external drive does not appear in Disk Utility?
Check its cable, connections, plus power. Apple notes that a device still missing from Disk Utility may need service. Read Apple's missing-device advice.
Should I keep scanning a clicking drive?
No. Stop DIY attempts if it clicks, grinds, or has suffered physical damage, especially when the files are irreplaceable. The linked recovery guide explains this boundary.
Get Disk Drill Free previews · Paid recovery
