July 2026 WiFi Shortlist
Best Free WiFi Heat Mapping Tools
The word “free” hides several limits in this category. Some tools measure a live network, while others only predict coverage from a floor plan.
⚡ TL;DR · Quick Answer
NetSpot is the best overall starting point due to its approachable interface, wide platform support, plus stronger upgrade path. Its free desktop edition mainly handles inspection, though, so choose WiFiman for a genuinely free mobile walkthrough or Hamina for free predictive planning.
★ Best Overall
NetSpot
9.0/10
Best for: Home users who want one interface for WiFi inspection, floor-plan surveys, plus eventual access to deeper paid analysis
  • Free desktop WiFi inspector for nearby network analysis
  • Apps available for Windows, macOS, Android, plus iOS
  • Clear upgrade path from scanning to measured surveys
  • Desktop product supports imported floor plans
2
WiFiman
8.6/10
Best for: UniFi households using a compatible LiDAR-equipped phone for a fast room-by-room coverage check
  • Completely free mobile download
  • Automatic floor-plan capture on supported devices
  • Real-time signal monitoring during a walkthrough
  • Includes speed plus latency testing
3
Hamina Network Planner
8.4/10
Best for: Network learners or small-site planners modeling no more than three access points before installation
  • Free predictive design with no survey hardware
  • Supports custom wall attenuation
  • Up to three simulated access points
  • Downlink coverage heatmaps included
Free WiFi Heat Mapping Tools Compared
These tools are compared by whether they measure an installed network or create a predictive model before installation. The scores reflect free-plan usefulness, setup friction, platform reach, plus limitations rather than laboratory RF accuracy.
Tool Measured Survey Predictive Planning Price Score
1.NetSpot PICK ● No ● No Free 9.0/10
2.WiFiman ● Yes ● No Free 8.6/10
3.Hamina Network Planner ● No ● Yes Free 8.4/10
4.UniFi Design Center ● No ● Yes Free 8.1/10
5.Cambium Wi-Fi Designer ● No ● Yes Free 7.7/10
The 5 Best Free WiFi Heat Mapping Tools, Reviewed
NetSpot
Windows, macOS, Android, iOS · Etwok
9.0/10
NetSpot is the most balanced starting point here. The free desktop edition scans nearby networks, shows channels plus signal levels, while its heatmap functions are available as demos. That distinction matters. A continuing measured desktop survey requires Home or a higher edition.
The wider toolset is the reason it still ranks first. NetSpot runs on four major platforms, while the paid desktop editions build on the same interface with actual floor-plan surveys. Home supports 2 zones, 2 snapshots per zone, 50 points per snapshot, plus three core heatmaps.
Download the free edition if you first need to diagnose channel crowding or understand the workflow. Do not mistake it for unlimited free heat mapping. For a single no-cost map, WiFiman may suit you better if your phone plus network meet its requirements.
Best forHome users who want one interface for WiFi inspection, floor-plan surveys, plus eventual access to deeper paid analysis
Standout featureIts broader product path covers live scanning, measured surveys, predictive planning, plus 20-plus visualizations
NetSpot Pros
  • Useful mix of signal, SNR, plus interference views in paid Home
NetSpot Cons
  • Free desktop heatmaps are demos, not unrestricted surveys
  • Report export is reserved for higher editions
  • Platform features differ, especially on iOS
Free $0 Network inspection plus heatmap demos; ongoing desktop surveys require an upgrade
Download NetSpot Free
WiFiman
iOS, Android · Ubiquiti
8.6/10
WiFiman offers the simplest route from phone to visual coverage map. Its mobile Floorplan Mapper records signal strength as you walk, so there is no need to click dozens of points on an imported drawing.
The catch is hardware dependence. Ubiquiti specifies a LiDAR-equipped mobile device for Floorplan Mapper, while richer signal, throughput, latency, plus roaming details require a UniFi Cloud Gateway. The desktop app does not include the mobile mapping features.
This is a strong choice for checking a living room, hallway, or small office after moving a mesh node. It is less suitable for formal survey documentation or vendor-neutral predictive planning.
Best forUniFi households using a compatible LiDAR-equipped phone for a fast room-by-room coverage check
Standout featureFloorplan Mapper records signal strength while the user physically walks through the space
WiFiman Pros
  • Very little setup for compatible UniFi homes
WiFiman Cons
  • Floorplan Mapper requires supported LiDAR hardware
  • Several connection metrics require a UniFi Gateway
  • No desktop heat-mapping workflow
Mobile App $0 Free download; mapping capabilities depend on device plus network hardware
Get WiFiman
Web app · Hamina Wireless
8.4/10
Hamina is a predictive planner rather than a walk-through survey app. Upload a floor plan, scale it, draw walls or other attenuating objects, then place virtual access points to estimate downlink coverage.
The free account is unusually useful for learning RF design. It permits 3 simulated APs, 5 AI wall-drawing runs, downlink heatmaps, plus customizable wall height or attenuation. That is enough for an apartment, house, café, or very small office.
There is no measured WiFi survey in the free plan. PDF export, uplink heatmaps, automatic AP placement, plus unlimited access points also require paid products. Treat its output as a planning model, then validate the installation with real measurements.
Best forNetwork learners or small-site planners modeling no more than three access points before installation
Standout featureThe free account includes customizable walls, downlink heatmaps, plus up to three simulated APs
Hamina Network Planner Pros
  • Works through a browser
Hamina Network Planner Cons
  • No measured site surveys in the free account
  • Three-AP ceiling limits larger projects
  • Free reports cannot be exported to PDF
Free Account $0 Predictive planning for up to 3 APs; no measured surveys
Planner $980/yr Unlimited AP placement, PDF reports, plus expanded planning features
Try Hamina Free
UniFi Design Center
Web app · Ubiquiti
8.1/10
UniFi Design Center turns an uploaded floor plan into a predictive deployment model. You can draw attenuation objects, place UniFi access points, compare primary or overlapping coverage, then review a data-rate heatmap.
A July 2026 update added automatic AP placement plus automatic channel planning. Those features save time during early drafts, particularly if you have not settled on access-point count or radio placement.
The tool is license-free, yet it is tied closely to Ubiquiti hardware. Its maps predict coverage rather than measure the live RF environment. They will not reveal a neighbor's overlapping channel, a noisy microwave, or poor client behavior.
Best forBuyers designing a new UniFi installation who want coverage estimates plus a matching equipment layout
Standout featureAutomatic AP placement plus automatic channel planning are built into a license-free browser tool
UniFi Design Center Pros
  • License-free browser access
  • Automatic access-point placement
  • Automatic channel planning
  • Customizable walls plus attenuation objects
  • Useful 2D, 3D, coverage, plus data-rate views
UniFi Design Center Cons
  • Centered on UniFi hardware
  • Predictive output is not a post-install survey
  • Requires careful floor-plan scaling for useful estimates
Design Center $0 License-free predictive planning for UniFi deployments
Open UniFi Design Center
Web app · Cambium Networks
7.7/10
Cambium Wi-Fi Designer keeps the process basic: upload a floor plan, scale it, add access points, then inspect predicted RF coverage. A guest mode lets you explore before creating an account.
The service is free to use. Registered users can save projects or email a completed heatmap with a bill of materials. It also provides a built-in drawing option if no floor-plan image is available.
Its main weakness is scope. This is a design aid for Cambium deployments, not a live signal survey. The interface feels more utilitarian than Hamina or the newer UniFi Design Center, though that simplicity can help on a quick quote.
Best forInstallers drafting a Cambium-based network who need a free heatmap plus bill of materials
Standout featureRegistered users can save or email a completed predictive heatmap with its equipment list
Cambium Wi-Fi Designer Pros
  • Free cloud-based planning tool
  • Guest demo available
  • Built-in floor-plan drawing
  • Saved heatmaps for registered users
  • Can produce a bill of materials
Cambium Wi-Fi Designer Cons
  • Predictive maps only
  • Best suited to Cambium access points
  • Fewer advanced analysis options than professional planners
Wi-Fi Designer $0 Free predictive planning; registration enables saving plus email output
Visit Cambium Wi-Fi Designer
How We Evaluated These Free WiFi Heat Mapping Tools
We compared the current free-plan limits shown in each maker's documentation as of July 2026. Scoring focused on whether the tool creates measured or predictive maps, floor-plan handling, device restrictions, platform access, export limits, plus how quickly a home user could reach a useful result.
Scores are editorial rather than controlled RF benchmarks. Predictive coverage cannot be fairly benchmarked against a walkthrough survey because the two methods answer different questions.
How to Choose a Free WiFi Heat Mapping Tool for Your Space
Start by deciding whether you need to map an existing network or plan a new one. For an installed network, use measured readings from WiFiman or a paid NetSpot survey. For access-point placement before installation, choose Hamina, UniFi Design Center, or Cambium Wi-Fi Designer.
Also check the hidden requirements. Mobile mapping may need LiDAR or matching network hardware. Browser planners may support only one vendor. A free desktop download may scan channels without letting you complete a reusable heatmap.
Common Free WiFi Heat Mapping Mistakes to Avoid
Do not judge WiFi from color alone. A green signal map can still hide channel contention, low SNR, packet loss, bad roaming, or a slow wired uplink. Keep the same phone or laptop throughout a survey since different radios report signal levels differently.
For predictive maps, scale the floor plan before placing access points. Mark concrete, brick, tile, metal shelving, plus elevator shafts realistically. A rough wall model can produce a polished map that has little connection to the finished space.
Which Free WiFi Heat Mapping Tool Should You Pick?
NetSpot earns first place because it is the easiest broad starting point for inspecting WiFi now, then moving into proper surveys later. Its free heatmaps are demos, so WiFiman is the better zero-cost choice for a compatible mobile walkthrough. Pick Hamina, UniFi Design Center, or Cambium Wi-Fi Designer when you need to model access-point placement before buying hardware.
Top pick NetSpot
Use a predictive planner before installation, then verify the finished network with measurements taken from the devices people actually use.
Free WiFi Heat Mapping Tool Questions
What is a WiFi heat map tool used for in a home or office network?
A WiFi heat map tool shows where your signal is strong, weak, or unstable across a floor plan. It helps you place access points, spot dead zones, then fix coverage problems before they turn into slow connections.
Which free WiFi heat mapping tools are best for small offices in 2026?
For small offices, the best free options usually are the ones that let you import a floor plan, walk the space, then create a coverage map without a paid subscription right away. NetSpot, Ekahau HeatMapper legacy alternatives, then open source site survey tools are common starting points if you only need basic visualization.
Can I make a WiFi heat map without buying special hardware?
Yes, most free tools can use a laptop or phone with a built in WiFi adapter for basic surveying. You will get better results if the adapter supports stable signal scanning, but you do not need dedicated hardware for a simple coverage map.
How accurate are free WiFi heat mapping tools compared with paid ones?
Free tools can be accurate enough for finding dead spots, poor placement, then obvious interference issues. Paid tools usually add better reporting, multi floor modeling, cloud sync, then more precise analysis, so free tools are best for quick planning or small networks.
What is the easiest free WiFi heat map tool for beginners?
The easiest tools are the ones with a simple walk survey workflow, automatic floor plan scaling, then clear color coded signal charts. If you want the least setup, look for a tool that lets you drag in a floor plan, mark your path, then export the map without extra configuration.
How do I create a WiFi heat map step by step with a free tool?
Start by uploading or drawing your floor plan, then calibrate the scale with a known wall length. Walk the space slowly while the tool records signal samples, then review the colored map for weak spots, overlap issues, then inconsistent coverage.
Can free WiFi heat map tools show interference from neighbors?
Some can show channel usage, noise, then nearby network strength, but not every free tool includes deep interference analysis. If you are troubleshooting apartment or dense office WiFi, choose a tool that displays channel overlap plus nearby SSIDs, not just signal bars.
Do WiFi heat map tools work on both 2.4 GHz and 5 GHz networks?
Many free tools can survey both bands if your adapter can detect them. That matters because 2.4 GHz often reaches farther while 5 GHz may be faster but drop off sooner through walls.
What should I look for before choosing a free WiFi heat map tool?
Check whether it supports your operating system, floor plan import, multi floor layouts, then export options like PDF or image files. You should also confirm whether the free version limits the number of surveys, access points, or saved projects.
Are there any free WiFi heat mapping tools that run on Mac or Windows?
Yes, several popular options support both Mac and Windows, but the free feature set can differ by platform. Before you install anything, verify that the survey mode, floor plan import, then export features are available on your operating system.
Can I use a phone app instead of a laptop for WiFi heat mapping?
You can for rough coverage checks, especially if you want a fast walk through with minimal setup. A laptop usually gives better control, more consistent scanning, then easier floor plan mapping for a true heat map.
What is the biggest mistake people make when generating a WiFi heat map?
The biggest mistake is walking too fast or taking too few samples, which makes the map look cleaner than the real network. Another common issue is using the wrong floor scale, then drawing false conclusions about where to add access points.
How do I interpret red, yellow, then green areas on a WiFi heat map?
Green usually means strong coverage, yellow means usable but weaker, then red marks areas where the signal may be too poor for stable performance. Treat the colors as a guide, then confirm with real speed tests or device testing in problem spots.
Can a free WiFi heat map tool help me decide where to place a mesh node?
Yes, that is one of the most practical uses. You can use the map to place the node halfway between a strong router signal plus a weak room, then avoid putting it where the backhaul signal is already bad.
What are good alternatives if a free WiFi heat map tool does not support my network?
If the tool cannot handle your setup, try a basic WiFi analyzer for channel checks, then use a manual floor plan with signal notes from different rooms. That is less polished, but it still helps you identify dead zones plus bad placement.
Is a free WiFi heat map tool enough for a multi floor building?
Sometimes, but only if the tool supports separate maps for each floor plus clear device labeling. For larger buildings, free software can still help with initial planning, although paid platforms are usually easier for repeated surveys.
How often should I rebuild a WiFi heat map after changing my network?
Rebuild it after major changes like moving an access point, adding a mesh unit, changing channels, or switching routers. If your office layout changes often, a fresh survey every few months can save time when users start reporting weak coverage again.
Download NetSpot Free · #1 Pick
