Mac recovery test · August 2026
Disk Drill Review 2026: Best Data Recovery Software for Mac
Disk Drill makes a stressful job unusually manageable on macOS. The free scan is useful, though meaningful recovery usually requires the $89 Pro plan.
9.1 /10
The Best Mac Recovery App for Most People Clear previews, strong Mac support, useful safety tools
Recommended
Disk Drill is our top general-purpose data recovery pick for Mac. It handles deleted files, formatted cards, unreadable disks, lost partitions, plus fragmented camera footage through a clean interface. Run the free scan first, then buy Pro only if your important files open correctly in Preview.
Disk Drill for Mac at a Glance
9.1/10
Disk Drill is a desktop data recovery utility for macOS. It searches drives, memory cards, disk images, plus supported mobile sources for deleted or inaccessible files.
Best forMac owners recovering files from external disks, memory cards, lost partitions, or recently formatted media
  • Universal multi-method scan
  • File preview before purchase
  • Advanced Camera Recovery
  • Byte-to-byte disk imaging
  • APFS plus HFS+ recovery support
Pricing Basic $0 for scanning plus preview · Pro $89/year for full recovery
Standout featureAdvanced Camera Recovery can reconstruct fragmented footage from original camera storage
  • Easy result browser
  • Excellent Mac compatibility
  • Useful imaging tools
  • Full Mac recovery usually costs $89/year
  • TRIM limits internal SSD recovery
  • Cannot fix physical drive damage
Disk Drill for Mac: How It Scored Across Our Recovery Criteria
01 Mac Recovery Workflow
9.4/10
02 Scanning Tools
9.2/10
03 File Preview Experience
9.0/10
04 Storage Device Support
9.1/10
05 Cost Plus Licensing
8.4/10
How We Evaluated Disk Drill for Mac Data Recovery
We reviewed the Disk Drill 6.3 workflow on macOS, covering installation, required permissions, device selection, Universal Scan, result filtering, file previews, scan-session handling, plus recovery destination safeguards. We also checked current macOS compatibility, official pricing, supported file systems, release notes, plus the behavior of its byte-to-byte imaging tools.
Scores favor actions that matter during an actual loss: finding the correct disk, avoiding writes to it, confirming files before payment, plus saving recovered data somewhere safe. We did not assign a universal recovery-rate figure because results change radically with overwriting, TRIM, encryption, fragmentation, plus hardware condition.
When Disk Drill Is the Wrong Choice for a Mac Drive
Do not keep scanning a drive that clicks, grinds, disconnects repeatedly, reports the wrong capacity, or fails to appear in Disk Utility. Software forces the device to perform more reads, which can turn a marginal mechanical problem into a dead drive. Power it down, then contact a reputable recovery lab.
Disk Drill is also unlikely to restore deleted data from a modern internal Mac SSD after TRIM has cleared the relevant blocks. Check Time Machine, iCloud Drive, app version history, email attachments, plus other synced devices before purchasing recovery software.
Disk Drill for Mac Recovery Features in Detail
A calm interface for a decidedly stressful task
9.4/10
Disk Drill gets the basic recovery flow right. Select a disk, click Search for lost data, inspect the results, then choose a different destination for restored files. Labels are understandable without prior recovery experience.
The result browser separates deleted, existing, plus reconstructed files. Filters for file type, size, date, name, or recovery chance keep a large scan from becoming one endless pile of cryptic filenames.
macOS may request Full Disk Access or an administrator password. That extra setup is expected for a utility that must read storage devices at a low level, though the permissions can look alarming if you were expecting a regular Mac app.
The upside
  • Simple scan-to-recovery path
  • Helpful file-type filters
  • Clear recovery-chance indicators
  • Works natively on modern Apple silicon Macs
The catch
  • macOS permissions add a setup step
  • Large scans still require patience
Disk Drill Review ↗
Scanning Tools
More depth than the single blue button suggests
9.2/10
The default Universal Scan combines several recovery methods, so most people do not need to pick a technical scan mode. It can look for recently deleted entries, damaged file-system records, lost partitions, plus files reconstructed from known signatures.
Advanced Camera Recovery is the more unusual feature. It targets fragmented footage on original camera cards or byte-level images, including media from common action cameras, drones, mirrorless cameras, plus dashcams. It is a specialized mode, not a magic improvement for every hard drive.
Disk Drill 6.3 also includes improved byte-to-byte imaging. This lets you copy a questionable drive sector by sector, then scan the image instead of repeatedly stressing the original device.
The upside
  • Automatic multi-method scanning
  • Special mode for fragmented camera media
  • Pause plus resume controls
  • Scans disk images without touching the source again
The catch
  • Advanced modes need a little reading
  • Deep scans can produce duplicate-looking results
See Advanced Camera Recovery details
The free version earns its keep before checkout
9.0/10
Preview is the feature to use before spending money. Photos can be inspected at a useful size, supported videos can be played, plus documents can often be opened directly from the result list. A working preview is much more meaningful than seeing a familiar filename alone.
Disk Drill also estimates each file’s recovery chance. Treat that label as guidance, not a promise. If the exact file does not preview correctly, paying for Pro will not repair overwritten content.
The upside
  • Previews available before purchase
  • Search works by filename or extension
  • Recovery estimates help prioritize files
  • Results can be reviewed while scanning continues
The catch
  • Some reconstructed files lose original names
  • A thumbnail does not prove every byte is intact
Learn how Preview works
Strong coverage for a mixed Mac desk
9.1/10
Disk Drill can scan Mac internal storage, external hard drives, USB sticks, SD cards, disk images, mobile-device backups, plus many RAID or network configurations. File-system support includes APFS, HFS+, FAT, exFAT, NTFS, ext2/3/4, BTRFS, plus RAW media.
Version 6.3 runs on macOS 10.15 through macOS 26. Older Disk Drill builds remain available for Macs stuck on earlier operating systems.
The main technical limit is not device support. It is the state of the data. A Mac SSD that has already processed deleted blocks through TRIM may have nothing left for software to retrieve.
The upside
  • Current support through macOS 26
  • Apple silicon compatibility
  • Broad file-system coverage
  • Useful SD card plus external-drive support
The catch
  • TRIMed SSD files are generally unrecoverable
  • Physical hardware failure needs a recovery lab
Check Disk Drill system requirements
Cost Plus Licensing
Reasonable for a real emergency, less appealing for one tiny file
8.4/10
Disk Drill Basic costs $0 to download. It can scan drives, show recoverable files, run previews, plus provide access to several disk utilities. Mac users should view Basic primarily as a scan plus preview edition, not an unlimited free recovery tool.
Disk Drill Pro is listed at $89 per year. That price makes sense if you have a card full of work, a lost project folder, or several disks to inspect. It feels steep when the target is one document that should have been in iCloud or Time Machine.
Check the renewal terms shown at checkout. User complaints sometimes focus on billing expectations rather than the scanner itself, so save the receipt plus note the renewal date.
The upside
  • Free scanning before purchase
  • Preview reduces blind purchases
  • One license covers the core recovery toolkit
  • Useful extras are included
The catch
  • Mac recovery usually requires Pro
  • Annual billing may not suit one-time use
  • Recovery is never guaranteed
Basic $0 Scan plus preview only on Mac; upgrade for full recovery
Pro $89/yr Full personal data recovery features
View current Disk Drill options
What Disk Drill Users Report About Real Recoveries
The poster says Disk Drill recovered photos from an inaccessible SD card in roughly 10 minutes after other tools failed to recognize or reconstruct the media properly.
Decent-Strawberry-97 · r/DataRecoveryHelp
A wedding videographer reported recovering roughly 40 to 50 GB from a mistakenly formatted Canon card after checking a small playable clip before paying.
puffpastry_bonanza · r/DataRecoveryHelp
One commenter said the scan appeared promising before purchase, yet the desired files could not be recovered. The same user was also unhappy with the support response.
Automatic_Fee_5857 · r/DataRecoveryHelp
A Mac user described recovering about 87,000 files from a drive Finder could not read, though the recovery required considerable sorting afterward.
Reddit user · r/macapps
Should Mac Users Download Disk Drill?
Disk Drill is the best Mac data recovery app for most nontechnical users who need to inspect an external drive, formatted card, lost partition, or unreadable volume. Its previews, filters, current macOS support, plus byte-level backup tool make the recovery process easier to judge before paying.
Skip it if the drive clicks, disappears from Disk Utility, or contains irreplaceable business data. Those cases belong with a professional lab. Internal SSD deletion is also a weak use case once TRIM has cleared the blocks.
Stop writing to the affected device, create a byte-to-byte image when possible, then confirm that the exact files open in Preview before buying Pro.
Disk Drill for Mac Questions, Answered
Is Disk Drill still worth using on Mac in 2026?
Yes, if you need a polished recovery tool that handles accidental deletes, lost partitions, USB drive issues, plus common photo or video recovery jobs. It is especially appealing if you want a Mac-friendly interface without a steep learning curve.
How does Disk Drill work on a Mac after I empty the Trash?
It scans the drive for files that have not been overwritten yet, then rebuilds what it can from file system traces plus known file signatures. The sooner you run a scan, the better your chances are.
Can Disk Drill recover files from an APFS drive on macOS?
Yes, it supports APFS volumes, which is important for newer Macs. Results still depend on whether the lost data has been overwritten, so stopping use of the drive right away matters.
Is Disk Drill better than Time Machine for recovering deleted files?
No, Time Machine is better for routine backups plus quick restores. Disk Drill is the fallback when you do not have a backup or when the file was lost from a drive Time Machine never protected.
What file types can Disk Drill recover on a Mac?
It can recover a wide range of formats, including documents, photos, videos, archives, plus audio files. The exact success rate depends on the storage device, file system, plus how much the drive has been used since the loss.
How much does Disk Drill cost for Mac in 2026?
Disk Drill uses a paid upgrade for recovery, with a free version that typically lets you scan plus preview files. If you want the latest pricing, check the official page at CleverFiles before buying.
Does the free version of Disk Drill actually recover anything?
Usually, the free version is mainly for scanning plus previewing, not full recovery. That is useful if you want to confirm your files are still recoverable before paying.
What should I do first if I deleted something important on my Mac?
Stop using the drive immediately, then install or run recovery software from a different drive if possible. Every new file write lowers the chance of getting the old data back.
Can Disk Drill recover data from a formatted external drive?
Often yes, especially if the format was quick rather than a full secure erase. The more the drive has been written to after formatting, the harder recovery becomes.
Does Disk Drill support recovering data from MacBook SSDs with TRIM?
It can scan SSDs with TRIM, but TRIM often reduces what can be recovered after deletion. For SSD cases, speed matters even more, so act right away if the file is important.
Is Disk Drill safe to use on a Mac?
Yes, it is a well-known recovery app from a long-running vendor. Still, download it only from the official site or Mac App Store, then avoid installing it on the same drive you are trying to recover.
How does Disk Drill compare with EaseUS Data Recovery for Mac?
Disk Drill usually feels more polished on macOS, with a cleaner interface plus useful extras like drive health tools. EaseUS can be a decent alternative if you want to compare scan results before choosing one.
Can Disk Drill recover files from a crashed external hard drive?
If the drive is detected by your Mac, there is a good chance it can scan it. If the drive clicks, disconnects repeatedly, or never mounts, a hardware problem may need professional repair first.
What is the best way to preview files before recovering them in Disk Drill?
Run a scan, then use the preview feature to open documents, images, or video clips before restoring them. This helps you avoid spending time on junk files or damaged duplicates.
When should I stop using Disk Drill and call a data recovery service instead?
If the drive is physically damaged, making strange noises, or contains business-critical files that cannot be lost, professional help is the safer move. Software works best for logical loss, not severe hardware failure.
Download Disk Drill Free scan · Top Mac pick
