Mac storage repair · August 2026
How to Fix a Corrupted Hard Drive on Mac? 5 Methods
A corrupted drive may have a damaged file system, a failing connection, or physical trouble. Start by protecting the files, then move from gentle checks to destructive repair.
Quick answer
Recover important files before changing the drive. If it still appears in Disk Utility, scan it with Disk Drill, save the results elsewhere, then run First Aid. Reformat only after your files are safe.
Stop using the drive if it clicks, grinds, disconnects repeatedly, or vanished after a drop. Do not erase it, run repeated scans, or attempt home repairs when the data matters. Disconnect it, then contact a recovery lab.
★ Editorial pick ★ 4.4 / 5
Recover Files Before Repair → Disk Drill for Mac
Scans corrupted or inaccessible storage · Previews found files before recovery · Supports macOS
✓ Free scan ✓ File previews ✓ Byte-to-byte backup
Scan the drive →
Top 5 Methods to Fix a Corrupted Hard Drive on Mac
Recover Files With Disk Drill Before Repairs
Safest first move when the corrupted drive still appears on your Mac
~15 min or more
Difficulty Easy
You need Disk Drill plus a healthy destination drive
Works for Internal or external Mac drives
Repair tools can change a damaged file system, so rescue important files first. Disk Drill can scan a drive that still appears in macOS, preview recoverable items, plus copy selected files to healthy storage.
  1. Stop saving files to the corrupted disk. Connect a separate healthy drive with enough free space for recovered data.
  2. Download Disk Drill from the official website, install it on a healthy disk, then open it.
  3. Select the corrupted physical drive. If the hardware seems unstable, use Byte-to-byte Backup first, then scan the resulting image instead of repeatedly reading the original.
  4. Click Search for lost data. Let the scan finish, or review found files while it continues.
  5. Preview several important files. Select the usable items, click Recover, then choose the separate healthy drive as the destination.
Disk Drill Review ↗
i Never recover files onto the same corrupted drive because new writes may overwrite data you still need.
Visit Disk Drill for Mac
Run First Aid in Disk Utility
Best for directory errors on a drive that stays connected
~5–30 min
Difficulty Easy
You need Disk Utility
Works for APFS, Mac OS Extended, FAT, ExFAT
Disk Utility’s First Aid checks a volume’s file-system structures, then repairs errors it recognizes. Back up or recover valuable files before running it whenever possible.
  1. Open Disk Utility from Applications › Utilities.
  2. Choose View › Show All Devices so the sidebar displays volumes, containers, plus physical devices.
  3. Select the lowest volume beneath the affected drive, then click First Aid › Run.
  4. Repeat First Aid upward through each remaining volume, the container, then the physical device.
  5. Eject the drive after First Aid completes, reconnect it, then test several files rather than checking only whether the disk opens.
i For a corrupted startup disk, restart in macOS Recovery, open Disk Utility there, then run First Aid on the startup volumes.
Check the Drive With fsck
Useful when Disk Utility will not complete its repair
~10–45 min
Difficulty Advanced
You need Terminal plus the disk identifier
Works for Unmounted Mac-accessible volumes
The command-line fsck utilities inspect file systems without Disk Utility’s graphical interface. A wrong disk identifier can target the wrong volume, so verify every character before running a command.
  1. Open Terminal, enter diskutil list , then identify the affected volume by its size, name, plus format.
  2. Write down its identifier, such as disk4s2 . Do not guess from the order shown in Finder.
  3. Unmount the volume with diskutil unmount /dev/disk4s2 , replacing the example identifier with the correct one.
  4. For an APFS volume, run sudo fsck_apfs -y /dev/disk4s2 . For HFS+, use sudo fsck_hfs -fy /dev/disk4s2 .
  5. When the check finishes, enter diskutil mount /dev/disk4s2 , then copy important files off immediately if the volume opens.
i Stop if Terminal reports repeated I/O errors. Those errors can point to hardware trouble rather than a repairable directory problem.
Erase and Reformat the Corrupted Drive
A clean reset after needed files are safely recovered
~5–20 min
Difficulty Moderate
You need Disk Utility plus a backup
Works for Drives without confirmed hardware failure
Reformatting replaces the damaged file-system structure, which often makes a logically corrupted disk usable again. It permanently removes the drive’s current contents, so this method belongs after recovery.
  1. Confirm that recovered files open from another drive. Check a few large videos, archives, photos, plus documents.
  2. Open Disk Utility, choose View › Show All Devices, then select the physical drive rather than an indented volume.
  3. Click Erase. Choose APFS for a Mac-only SSD or modern Mac drive. Choose ExFAT for routine sharing with Windows.
  4. Use GUID Partition Map when the Scheme menu appears, enter a clear drive name, then click Erase.
  5. Copy a small test folder to the reformatted disk, eject it properly, reconnect it, then confirm the files remain readable.
i Retire the drive if corruption returns soon after a successful erase. Reformatting cannot repair worn heads, bad electronics, or other physical defects.
Send the Drive to a Recovery Lab
Right choice for clicking, impact damage, or a disk that never appears
~2–10 days
Difficulty Easy to arrange
You need A reputable recovery lab
Works for Physically damaged HDDs or failed devices
Software cannot repair a broken read head, seized motor, damaged controller, or severe electronic failure. A recovery lab may work from the original media using specialized hardware, though results are never guaranteed.
  1. Shut down the Mac or disconnect the external drive if you hear clicking, grinding, repeated spin-up sounds, or sudden dropouts.
  2. Do not open the drive enclosure, freeze the disk, tap it, or keep reconnecting it to see if it works once more.
  3. Ask the lab whether diagnosis is free, whether approval is required before paid work, plus how recovered data will be returned.
  4. Describe any drop, liquid exposure, power surge, encryption, repair attempt, or unusual sound when submitting the case.
  5. Package the powered-off drive in an antistatic bag with firm padding. Keep your password or recovery key available if the data is encrypted.
i For irreplaceable data, early lab evaluation is usually safer than repeated scans of a mechanically unstable drive.
How to Tell Logical Corruption From Physical Drive Failure
A drive that appears in Disk Utility with the correct capacity but refuses to mount often has a file-system or partition problem. That is a reasonable case for recovery software, First Aid, or fsck.
Clicking, grinding, no spin, a burned smell, wildly incorrect capacity, plus repeated disconnections point toward hardware trouble. Software cannot make damaged mechanical parts reliable.
When Not to Repair a Corrupted Mac Drive Yourself
Skip do-it-yourself repair if the missing files are the only copies of legal records, paid client work, research, or family media. The same applies after liquid exposure, a hard drop, or an electrical surge.
Encryption also raises the stakes. Keep the FileVault password, recovery key, or external-drive password available. A successful physical recovery may still produce unreadable data without the key.
Choose the Right Method for a Corrupted Mac Hard Drive
Begin with the least destructive option that fits the drive’s symptoms.
1. Recover Files With Disk Drill Before Repairs TRY FIRST Protecting files before repair ~15 min or more ● 82%
2. Run First Aid in Disk Utility Common file-system errors ~5–30 min ● 78%
3. Check the Drive With fsck Errors First Aid cannot clear ~10–45 min ● 62%
4. Erase and Reformat the Corrupted Drive Reusing a logically damaged disk ~5–20 min ● 90%
5. Send the Drive to a Recovery Lab Physical damage or missing drives ~2–10 days ● 70%
Which Mac Hard Drive Fix Should You Try?
Start with Disk Drill if the drive contains files you cannot replace. Recover them to healthy storage before First Aid, fsck, or erasing changes the damaged file system. First Aid suits ordinary directory errors, while reformatting offers a clean reset once the data is safe.
A drive that clicks, disappears, or repeatedly disconnects needs a different response. Power it down, skip software repairs, then let a recovery lab assess the hardware.
Recover first, repair second, then replace the drive if the same corruption or connection problem returns.
Common Questions About Corrupted Mac Hard Drives
How do I tell if a hard drive on my Mac is corrupted or just disconnected badly?
Open Disk Utility first. If the drive shows up but won't mount, displays errors, or asks to be initialized, corruption is likely. If it does not appear at all, try a different cable, port, or enclosure before assuming the drive is damaged.
What is the safest first step before trying to repair a corrupted hard drive on Mac?
Stop using the drive right away. Any new writes can make file recovery harder, so copy off anything important only if the Mac can still read the drive. If the data matters, make a backup before running repair tools.
How do I use First Aid in Disk Utility to fix a corrupted external hard drive on Mac?
Open Disk Utility, choose View, then select Show All Devices. Pick the physical drive or the volume, click First Aid, then follow the prompts to run the repair. If First Aid reports that it cannot repair the disk, move to recovery options before retrying random fixes.
Why does Disk Utility say First Aid failed on my Mac drive?
That usually means the file system damage is beyond what First Aid can repair. The drive may have bad sectors, a failing controller, or severe directory corruption. At that point, back up what you can or use recovery software before reformatting.
Should I repair the volume or the physical disk first in Disk Utility?
Start with the volume if it mounts, then run First Aid on the physical disk if needed. If the volume is not available, select the top-level device instead. That order helps you catch simple file system problems before deeper device issues.
How do I recover files from a corrupted hard drive on a Mac before formatting it?
Use a recovery app that can scan the drive without writing to it, then save recovered files to a different disk. Never restore recovered data back onto the same corrupted drive. If the drive makes clicking sounds, stop and consider professional recovery instead.
Can I fix a corrupted hard drive on Mac without erasing it?
Yes, sometimes. Disk Utility First Aid, safe mounting, or checking the drive in Recovery Mode can fix file system damage without erasing data. If those steps fail, erasing may be the only reliable repair, so save files first if possible.
When should I reformat a corrupted hard drive on Mac instead of trying more repairs?
Reformat when First Aid keeps failing, the drive repeatedly disconnects, or the file system stays unreadable after recovery attempts. Reformatting removes the corruption but also wipes the data, so it should come after backup or file recovery. If the drive fails again after a fresh format, replace it.
How do I erase a corrupted external hard drive on Mac and make it usable again?
Open Disk Utility, select the top-level drive, click Erase, then choose a format like APFS for Mac-only use or exFAT for Mac plus Windows. Pick GUID Partition Map when available. If Disk Utility cannot erase it, try Recovery Mode first, then test the drive on another Mac.
What format should I use after fixing a corrupted hard drive on Mac?
Use APFS for modern Macs if the drive stays in the Apple ecosystem. Choose exFAT if you need the drive to work with Windows too. Avoid older formats unless you specifically need compatibility with older software or hardware.
Why does my external hard drive keep corrupting on my Mac after I fix it?
A recurring corruption problem usually points to the drive itself, a bad cable, unstable power, or unsafe removal. Try a different cable, port, or powered enclosure, then run disk checks again. If the issue returns, replace the drive before it fails completely.
Can I repair a corrupted Time Machine drive on Mac the same way as a normal hard drive?
You can run First Aid, but Time Machine disks sometimes need a fresh erase if the backup structure is badly damaged. If you want to keep old backups, copy important files first if the drive still mounts. After repair or reformatting, set up Time Machine again from scratch.
What should I do if my Mac says the drive is not readable?
Click Ignore if you need time to back up data, then open Disk Utility to see whether the drive mounts. Run First Aid if it appears there. If the Mac keeps asking to initialize the drive, do not erase it until you check whether recovery is still possible.
Is there a way to fix a corrupted hard drive on Mac using Terminal?
Yes, experienced users can inspect disks with `diskutil list` or try mounting with `diskutil mountDisk`. Terminal is useful when Disk Utility does not behave well, but it is easy to make a mistake. If you are unsure, stick with Disk Utility or a recovery tool.
How do I fix a corrupted hard drive on Mac if it is the startup disk?
Boot into macOS Recovery by restarting, then hold Command and R. From there, open Disk Utility and run First Aid on the startup volume or container. If the Mac will not boot at all, use Recovery first, then consider reinstalling macOS after the disk checks out.
Will running First Aid delete files on a corrupted Mac hard drive?
First Aid is designed to repair the file system without erasing files. That said, any repair on a damaged disk carries some risk, especially if the drive is failing physically. If the data is important, back it up or clone it first.
What are the warning signs that a corrupted hard drive on Mac is actually failing hardware?
Frequent disconnects, very slow mounts, clicking or grinding sounds, repeated I O errors, plus failed repairs are red flags. File system corruption can happen once, but repeat failures usually mean hardware trouble. At that point, limit use and focus on recovery.
How do I prevent a hard drive from getting corrupted again on my Mac?
Always eject the drive before unplugging it, avoid cheap cables, keep backups, then let macOS finish writes before disconnecting power. If the drive is old, test it regularly in Disk Utility. Replacing a suspicious cable costs far less than recovering a dead drive.
