Dead MacBook recovery steps
How to Recover Data From a Dead MacBook?
A MacBook that will not start is not automatically empty. The best recovery route depends on whether its internal storage still appears, whether a backup exists, plus what caused the failure.
Quick answer
First, stop using the MacBook if it suffered liquid, impact, heat, or electrical damage. If the storage can still be shared with another Mac, scan it using Disk Drill, preview the files, then recover them to a separate external drive.
Do not erase the disk, reinstall macOS, run repeated First Aid repairs, or save recovered files back to the source. If the MacBook has liquid damage, a swollen battery, burning odor, clicking storage, or unstable power, leave it off plus contact a recovery lab.
★ Editorial pick ★ 4.5 / 5
Scan an Accessible MacBook Drive → Disk Drill
Scans APFS or HFS storage · Previews discovered files before recovery · Runs on macOS plus Windows
✓ Available since 2011 ✓ APFS and HFS support ✓ M-series and T2 support
Try the scan →
When Software Cannot Recover a Dead MacBook
Recovery software needs the storage device to remain visible through macOS, an enclosure, Target Disk Mode, or Share Disk. It cannot scan a drive that never appears to the working Mac.
There is another limit with recent MacBooks. Their soldered storage, hardware-backed encryption, plus board-specific components can make ordinary drive removal useless. If the logic board cannot unlock the data, board-level repair may be the only realistic path.
What a Dead MacBook Actually Means for File Recovery
“Dead” covers several very different failures. A black screen could be a bad display, empty battery, broken macOS installation, failed logic board, or liquid-damaged power circuit. Files may still be intact in several of those cases.
Test access rather than guessing. If Recovery loads or another Mac sees the internal volume, use a software or direct-copy method. If the Mac shows physical damage or cannot expose storage at all, stop home troubleshooting.
Choose the Right Dead MacBook Recovery Method
Start with the least invasive option that fits the failure.
1. Scan the MacBook Drive With Disk Drill TRY FIRST Readable storage, failed macOS ~30–90 min ● 78%
2. Copy Files Through macOS Recovery Mac reaches Recovery ~20–60 min ● 72%
3. Restore Files From Time Machine or iCloud Existing backup or cloud sync ~15 min–several hours ● 95%
4. Read a Removable MacBook Drive Externally Older Mac with removable storage ~30–90 min ● 65%
5. Send the MacBook to a Recovery Lab Physical or logic-board damage ~3–14 days ● 60%
Top 5 Ways to Recover Data From a Dead MacBook
Best when the dead Mac still exposes its internal storage to another Mac
~30–90 min
Difficulty Moderate
You need Second Mac, cable, external drive
Works for Intel, Apple silicon
If the MacBook cannot boot normally but its storage remains readable, connect it to a working Mac, then scan the exposed volume with Disk Drill. Intel models use Target Disk Mode, while Apple silicon models provide Share Disk through macOS Recovery. (support.apple.com)
  1. Connect an empty external drive to the working Mac. It must have enough room for recovered files.
  2. Link both Macs with the proper USB-C or Thunderbolt cable. Macs running macOS 11 or later may require Thunderbolt for Target Disk Mode. (support.apple.com)
  3. On an Intel MacBook, switch it on while holding T. On Apple silicon, hold the power button until startup options appear, select Options, open Recovery, then use Utilities > Share Disk.
  4. Install Disk Drill on the working Mac, not on the damaged MacBook volume.
  5. Select the exposed MacBook disk in Disk Drill, click Search for lost data, then let every scan stage finish.
  6. Preview important files, select them, click Recover, then save them to the empty external drive.
Disk Drill Review ↗
i If the internal disk disconnects, produces repeated read errors, or vanishes during scanning, stop before its condition gets worse.
Open the Disk Drill website
Useful when macOS fails to load but Recovery still recognizes the internal volume
~20–60 min
Difficulty Moderate
You need External drive
A MacBook that looks dead may only have a damaged startup system. Recovery can sometimes unlock or mount the data volume long enough to copy files without running a full recovery scan.
  1. Connect a blank external drive with enough free space for the files you need.
  2. For Apple silicon, hold the power button until Options appears. For Intel, start while holding Command-R. (support.apple.com)
  3. Open Disk Utility, choose View > Show All Devices, then select the internal data volume.
  4. Click Mount. Enter the Mac login password if FileVault asks you to unlock the volume.
  5. Quit Disk Utility, open Utilities > Terminal, then copy essential folders to the external drive with ditto or cp -R .
  6. Open a few copied documents, photos, or videos on another Mac before treating the transfer as complete.
i Do not erase, partition, or reinstall macOS before the files have been copied elsewhere.
Safest when a backup or cloud copy predates the MacBook failure
Difficulty Easy
You need Backup disk or Apple Account
Works for Any replacement Mac
Backups avoid placing more stress on questionable hardware. Check Time Machine, iCloud Drive, iCloud Photos, plus any work or school cloud account before attempting invasive repair.
  1. Connect the Time Machine disk to a working or replacement Mac.
  2. During Mac setup, choose the option to transfer from a Mac, Time Machine backup, or startup disk.
  3. Select the newest backup created before the failure, then restore the user account or the specific categories you need.
  4. Sign in at iCloud.com to check iCloud Drive, Photos, Notes, Contacts, plus recently deleted items.
  5. Check Dropbox, OneDrive, Google Drive, Adobe cloud storage, email attachments, phone imports, plus shared project folders.
  6. Compare several restored files with older copies before wiping or repairing the dead MacBook.
i A Time Machine backup may be older than the last files saved locally, so verify its backup date.
An option for older models whose SSD or hard drive is not soldered to the logic board
~30–90 min
Difficulty Hard
You need Correct enclosure, tools, second Mac
Works for Certain older Intel models
Some older MacBooks have a removable SATA drive or proprietary Apple SSD. Once placed in the correct enclosure, that device can be mounted or scanned from another Mac.
  1. Look up the exact model identifier or serial number before buying an enclosure. Connector shapes that look similar may still be incompatible.
  2. Shut the MacBook down, unplug power, then stop if the battery is swollen, wet, hot, or physically damaged.
  3. Follow a model-specific teardown guide to disconnect the battery before touching the storage device.
  4. Place the removed drive in a compatible enclosure or connect it through the correct adapter.
  5. Attach it to a working Mac, unlock it with the original login password if FileVault is enabled, then copy readable files first.
  6. If Finder cannot copy the files, scan the externalized drive with Disk Drill, then recover results onto a separate healthy disk.
i Do not attempt this on a soldered-storage model. Opening the wrong MacBook can create damage without improving access to its data.
The right move after liquid damage, electrical failure, severe impact, or unstable storage
~3–14 days
Difficulty Easy to arrange
You need Model details, password, budget
Works for Physical or board-level failures
Modern MacBook storage may be soldered, encrypted, plus dependent on components from the original logic board. A capable lab may repair the board only long enough to unlock the Mac, boot it, or extract the files.
  1. Stop powering on a liquid-damaged, burnt, clicking, or repeatedly restarting MacBook.
  2. Write down the model, year, failure symptoms, liquid history, repair attempts, plus the folders that matter most.
  3. Ask the lab whether it performs board-level Mac repair in-house rather than forwarding every job elsewhere.
  4. Confirm that the quote covers diagnosis, recovery work, return media, plus what happens if no usable data is recovered.
  5. Provide the login or recovery credentials only through the lab’s secure process since encrypted storage may require them.
  6. When the recovered drive arrives, inspect a sample from every important folder before closing the case.
i A repair shop that replaces the logic board may return a working laptop without the original data. State clearly that file recovery comes first.
Which Dead MacBook Recovery Method Should You Use?
Use Disk Drill first when another Mac can see the dead MacBook’s internal volume. It gives you a practical way to scan, preview, then copy recoverable files onto separate storage. If Recovery opens, try a direct copy before deeper scanning. Choose a backup for the lowest-risk restore, while liquid damage, electrical failure, or disappearing storage belongs with a recovery lab.
Protect the original storage first: make one careful recovery attempt, save everything elsewhere, then worry about repairing the MacBook.
Dead MacBook Data Recovery Questions
How do I recover files from a MacBook that will not turn on at all?
First, remove the MacBook from power, then try a different charger plus outlet in case the issue is the adapter, not the laptop. If it still stays dead, your best path is to take the internal storage to a data recovery shop or a Mac repair shop that can test the logic board plus the drive separately.
Can I get my data back if the MacBook screen is black but the machine seems to power on?
Yes, often you can. Connect an external display, then try an external keyboard or trackpad to see whether the Mac is booting with only the built-in display failing.
Is it possible to recover data from a dead MacBook if I never backed it up?
Usually yes, if the storage itself still works. The big question is whether your Mac has a removable SSD, a soldered SSD, or a T2 or Apple silicon setup, because that changes the recovery path a lot.
What should I do first before taking a dead MacBook apart?
Stop powering it on repeatedly if you smell burning, hear clicking, or notice liquid damage. After that, gather the model number, note any symptoms, then contact a repair service that handles data recovery before you open the case.
Can I recover files from a MacBook with water damage?
Sometimes, but time matters. Keep it powered off, do not charge it, then have it checked quickly since corrosion can spread inside the board plus storage area.
How do I know whether the problem is the logic board or the storage drive?
A repair tech can often test that for you, but you can also look for clues. If the Mac shows signs of power yet never chimes, never shows a display, or shuts off randomly, the logic board may be the main issue rather than the drive.
Can I remove the SSD from my MacBook and read it on another computer?
Only on certain older Intel MacBook models with removable SSDs. Many newer MacBooks use soldered storage, so a simple SSD swap is not an option.
What is the safest way to recover data from a dead MacBook with Apple silicon?
If the Mac will not start, professional recovery is often the safest route because the storage is integrated with the chip architecture. If you have another working Mac plus a recent backup, try Migration Assistant, Time Machine, or iCloud first.
Does Target Disk Mode work on a dead MacBook?
Only if the Mac can still power on enough to enter that mode. If the machine is fully dead, Target Disk Mode will not help.
How can I use a Time Machine backup after my MacBook dies?
Connect your backup drive to another Mac, then open Migration Assistant or Time Machine to restore your files. If you only need a few documents, you can also browse the backup manually in Finder.
What if my MacBook shows a folder with a question mark?
That usually means the Mac cannot find a bootable system volume, not that all data is gone. Start by checking whether the drive appears in Disk Utility or Recovery Mode, then copy the data off if the volume mounts.
How much does dead MacBook data recovery usually cost?
It depends on the failure type, storage type, plus whether the drive is physically damaged. Simple software or file-system recovery is cheaper than chip-level board work or clean-room style repair.
Should I try free recovery software on a dead MacBook?
Only if the Mac still boots or the drive is visible in another Mac, because software cannot fix a machine that has no power. If the storage is detected, test read-only options first so you do not overwrite anything.
Can I recover photos from a dead MacBook without paying for professional recovery?
Yes, if those photos were syncing to iCloud Photos, Google Photos, or another cloud service. Also check any external drives, old phones, or shared libraries before you spend money on repair.
What files are most likely to be recoverable after a MacBook dies?
User documents, photos, videos, plus project folders are often the first things recoverable if the storage is intact. App settings, caches, or temporary files are less reliable because they may not have been saved in a complete way.
How long does it take to recover data from a dead MacBook?
A simple case can take a day or two, while a board-level or chip-level job can take longer. The timeline mostly depends on how badly the Mac failed plus whether parts are available.
Is it better to repair the MacBook first or recover the data first?
Recover data first if the Mac is unstable, dead, or showing liquid damage. Once your files are safe, you can decide whether the laptop is worth repairing or replacing.
Can I recover data from a dead MacBook if FileVault was enabled?
Yes, but you will need the correct login password or recovery key to unlock the data. Without that, even a successful hardware recovery may leave the files unreadable.
What are my alternatives if the MacBook storage is destroyed?
Check cloud backups, email attachments, shared project folders, USB drives, plus old iPhone or iPad backups. If the drive itself is physically gone, those alternate sources may be the only practical way to rebuild your files.
Where can I get help recovering data from a dead MacBook in October 2026?
Look for a Mac repair shop or data recovery service that specifically mentions Apple laptop recovery, not just general computer repair. If you want to compare options, ask whether they handle removable SSDs, soldered storage, liquid damage, plus FileVault cases before you ship the machine.
