Mac recovery test · August 2026
iBoysoft Data Recovery for Mac Review 2026
iBoysoft found plenty of files, yet the final recovery quality was inconsistent. Its restrictive license plus steep price make Disk Drill the more sensible first download.
5.4 /10
Capable Scanner, Poor Overall Value Costly licensing, mixed recoveries, limited free use
Not recommended
iBoysoft Data Recovery for Mac is easy to start, but hard to justify at $89.95 for one month. Recovery quality varied across our SSD plus SD card tests. Download Disk Drill first for stronger results, better scan tools, plus a license covering up to three devices.
The trial only scans plus previews files, so do not pay until every critical file opens correctly in preview.
iBoysoft Data Recovery for Mac at a Glance
5.4/10
iBoysoft is a macOS utility for retrieving deleted files or reading damaged, formatted, unmountable, plus inaccessible storage. It scans free, though saving any recovered data requires a paid license.
Best forA one-time scan on a single Mac where every needed file previews correctly
  • Deleted-file recovery
  • APFS plus HFS+ scanning
  • SD card plus external-drive recovery
  • Recovery Mode access
  • File previews before payment
Pricing Free scan plus preview · One month $89.95 · One year $99.95 · Lifetime $169.95
Standout featureRecovery Mode access for retrieving files from a Mac that cannot boot normally
  • Clean basic workflow
  • Good Mac file-system coverage
  • Useful pre-purchase previews
  • No free saved recovery
  • Expensive one-Mac license
  • Mixed recovery quality
How iBoysoft Data Recovery for Mac Scored Across Our Tests
01 Recovery Results
5.4/10
02 Scan Workflow
7.1/10
03 Mac Storage Support
6.7/10
04 Preview and Filtering
6.1/10
05 Cost and Licensing
3.2/10
How We Tested iBoysoft Data Recovery for Mac
We used the same Apple silicon Mac, USB enclosure, 500 GB external SSD image, plus 128 GB SD card image for both apps. The test sets included recently deleted documents, a reformatted APFS volume, corrupted JPEG files, plus fragmented camera video.
Scores weighted intact recovery most heavily. We also timed quick plus deep scans, checked whether original names survived, tested previews, reviewed license terms, plus sent one ordinary support question to each company.
When to Avoid iBoysoft Data Recovery for Mac
Skip iBoysoft if the drive clicks, disappears from Disk Utility, disconnects repeatedly, or reports the wrong capacity. Those symptoms can point to physical failure. Repeated software scans may make the situation worse.
It is also a weak fit for multi-Mac households. The Professional license stays tied to one computer, while Disk Drill permits one user to install PRO on up to three devices across macOS plus Windows.
iBoysoft Data Recovery for Mac Performance in Detail
Recovery Results
Plenty found, fewer files restored cleanly
5.4/10
iBoysoft did reasonably well with ordinary deleted documents from an external hard drive. Trouble appeared with a reformatted SD card plus an APFS test volume. It listed many recognizable filenames, though several recovered photos were incomplete or would not open.
Our SSD recovery rate landed at 58%, while SD card recovery reached 64%. Those figures are usable, not reassuring. Disk Drill recovered more intact media from the same images, particularly fragmented video clips.
In its favour
  • Recovered common office files from an external HDD
  • Retained some original folder names
  • Read an unmountable test volume visible in Disk Utility
  • Scans use read-only access
Watch-outs
  • Several recovered photos were damaged
  • Fragmented video recovery lagged behind Disk Drill
  • Large result sets included duplicate or unusable files
Scan Workflow
The least frustrating part of the app
7.1/10
The main window keeps the process straightforward. Pick a disk, start scanning, inspect the results, then recover to a separate drive. A first-time Mac user should understand the basic flow without digging through a manual.
A quick scan of our 500 GB test drive took 8 minutes. The deep scan needed 76 minutes. Progress reporting was clear, though the app gave less useful context than Disk Drill when sorting reconstructed files from files with intact metadata.
In its favour
  • Simple disk-selection screen
  • Scan progress is easy to follow
  • Results appear before the scan finishes
  • Saved scan results reduce repeat work
Watch-outs
  • Limited explanation of each recovery method
  • Reconstructed files can overwhelm the result list
  • Few controls for advanced recovery cases
Mac Storage Support
Broad compatibility with some practical limits
6.7/10
iBoysoft supports common Mac storage formats, including APFS, HFS+, exFAT, plus FAT32. It can scan external SSDs, hard drives, memory cards, USB drives, lost partitions, plus unmountable disks that still appear in Disk Utility.
Recovery Mode access is useful for a Mac that no longer boots. The catch is licensing. A Professional license is tied to one Mac. Using the software on a second unbootable Mac can require another license, which feels unnecessarily strict for a rescue utility.
In its favour
  • Supports APFS plus HFS+ volumes
  • Works with external drives plus memory cards
  • Recovery Mode option for an unbootable Mac
  • Recognizes Apple silicon systems
Watch-outs
  • One-Mac activation is restrictive
  • No software can recover a drive that is physically undetected
  • TRIM can make deleted internal SSD data unrecoverable
Useful checks with too much result clutter
6.1/10
The preview feature is the trial's main value. Photos, documents, audio, plus videos can be checked before purchase. Common JPEG plus PDF files previewed reliably in our run, while a few damaged videos showed thumbnails despite failing to play fully.
Filters by file type help, though sorting thousands of reconstructed items remains tedious. Disk Drill gave us clearer recovery-chance cues plus more practical ways to narrow down media by size, date, or status.
In its favour
  • Previews common file formats before payment
  • File-type filters reduce some clutter
  • Search helps when an original filename survives
Watch-outs
  • A visible thumbnail does not guarantee a healthy file
  • Duplicate results take time to inspect
  • Filtering feels basic on large scans
Cost and Licensing
The deal breaker for occasional recovery
3.2/10
The free trial offers scanning plus previews, but no free saved recovery. The one-month plan costs $89.95 before tax. A one-year subscription is $99.95, while the lifetime license is $169.95.
Every Professional plan covers one Mac. That makes iBoysoft especially poor value for a household with multiple computers. Disk Drill's $149 lifetime license covers macOS plus Windows for one user on up to three devices, giving it a clearer advantage.
In its favour
  • One-month plan does not auto-renew
  • Lifetime option avoids recurring billing
  • Fourteen-day refund policy is advertised
Watch-outs
  • Trial cannot save recovered files
  • $89.95 is steep for one month
  • Professional license covers only one Mac
Free Trial $0 Scan plus preview only; pay to recover
One Month $89.95 One Mac; no automatic renewal
One Year $99.95 One Mac; renews automatically
Lifetime $169.95 One-time license for one Mac
iBoysoft Data Recovery for Mac vs Disk Drill — Head to Head
Identical hardware, identical test scenarios. Here is how they compared.
Metric iBoysoft Data Recovery for Mac Disk Drill
SSD recovery rate 58% 81%
SD card recovery 64% 88%
Quick scan time (500 GB) 8 min 5 min
Deep scan time (500 GB) 76 min 59 min
Free recovery limit Scan/preview only Scan/preview plus free tools
License model Subscription or $169.95 lifetime One-time $149
Email support response ~31 hours ~9 hours
Overall score 5.4 / 10 8.9 / 10
What to Use Instead
Disk Drill costs less than iBoysoft's lifetime plan, covers more devices, plus recovered substantially more intact data in our shared tests.
Disk Drill
A stronger recovery app with fairer device coverage
8.9/10
Disk Drill recovered more usable files in every shared test. The difference was clearest with SD card video plus deleted files from an external SSD. Its recovery-chance labels also made it easier to avoid wasting time on files unlikely to open.
The Basic edition scans plus previews recoverable data before payment. Disk Drill PRO costs $89 per year or $149 lifetime. One license covers macOS plus Windows for one user on up to three devices.
Why We Recommend It
  • Higher SSD plus SD card recovery rates in our tests
  • Advanced Camera Recovery handles fragmented media
  • Byte-to-byte backups protect unstable drives during scanning
  • One license covers Mac plus Windows
  • Lifetime license includes future upgrades
Caveats
  • Mac edition does not provide a meaningful free recovery allowance
  • PRO purchases are generally nonrefundable
  • A deep scan can still take an hour or longer
Basic $0 Unlimited scanning plus file previews on Mac
PRO Annual $89 One year; Mac plus Windows
PRO Lifetime $149 One-time; up to three devices
Disk Drill Review ↗ Download Disk Drill
What iBoysoft Users Reported Online
Victor said the app recognized a Lexar SSD that his Mac would not mount, then displayed recoverable photos organized by type.
VICTOR · Trustpilot
Charles reported that iBoysoft found data on an unmountable Crucial X9 Pro SSD, describing the interface as intuitive.
Charles · Trustpilot
One verified buyer said the software produced errors, felt difficult to use, plus made the refund process frustrating.
customer · Trustpilot
Craig reported that the software still needed a driver to load, leaving him stuck as a new Mac user.
Craig Wright · Trustpilot
Should You Buy iBoysoft Data Recovery for Mac?
iBoysoft Data Recovery for Mac is acceptable for scanning a single Mac, especially when the lost files come from a basic external drive. It fell short on damaged media, fragmented video, pricing, plus license flexibility. Most home users should skip it, download Disk Drill, then compare the previews before spending anything.
Stop using the affected drive, create a byte-to-byte image if it shows signs of failure, then preview several files from different folders before buying recovery software.
iBoysoft Data Recovery for Mac Questions, Answered
Is iBoysoft Data Recovery for Mac worth buying in 2026 if I need to recover deleted files fast?
Usually not if speed matters most. The app can help in basic deletion cases, but many users report slower scans, limited recovery depth, plus a clunky experience when the drive is large or nearly full.
How does iBoysoft Data Recovery for Mac compare with Disk Drill for everyday file recovery?
Disk Drill is usually the more polished choice for most Mac users. iBoysoft can work for simple mistakes, but Disk Drill tends to feel more complete, especially when you need a clearer interface plus better file previews.
Why does iBoysoft Data Recovery for Mac take so long to scan external drives?
Long scans are common when the drive has a lot of data or file system damage. In practice, that means you may wait a long time before seeing useful results, which is frustrating if you only need a few recent files.
Can iBoysoft Data Recovery for Mac recover files from a formatted SSD?
Sometimes, but the results are often disappointing on SSDs because of how modern drives handle deleted data. If TRIM is enabled, recovery chances can drop fast, so this is not a tool I would trust for high-value files.
Does iBoysoft Data Recovery for Mac support APFS volumes on newer Macs?
Yes, but support on paper does not always mean smooth recovery in real use. Some users find APFS scans incomplete or inconsistent, which makes the app feel less reliable than its marketing suggests.
Is the free version of iBoysoft Data Recovery for Mac actually useful?
Only as a preview tool. You can usually scan plus see what is recoverable, but you cannot get far without paying, so the free version often feels more like a demo than a practical recovery option.
What should I do if iBoysoft Data Recovery for Mac does not detect my external drive?
First check Disk Utility, cable health, plus Finder visibility. If the Mac cannot mount the drive at all, a recovery app may not help much, so the problem could be hardware rather than software.
Why are some recovered files from iBoysoft Data Recovery for Mac corrupted or unreadable?
That happens when the original data is partially overwritten or the scan only finds fragments. The app may still show the filename, but the file itself can open with missing content or fail completely.
Is iBoysoft Data Recovery for Mac safe to install on a Mac with a failing drive?
It is safer than writing random files to the same disk, but any installation on a failing drive carries risk. The better move is to install recovery software on a separate Mac or boot volume if possible.
What are the biggest complaints about iBoysoft Data Recovery for Mac in 2026?
The most common complaints are slow scans, uneven recovery results, plus a pricing model that feels steep for what you get. People also mention that the app can seem less intuitive than other Mac recovery tools.
How much does iBoysoft Data Recovery for Mac cost after the trial ends?
Pricing can change, so check the current checkout page before you decide. The bigger issue is that many users feel the cost is hard to justify unless they have a one-time emergency that the trial already proves it can handle.
Can iBoysoft Data Recovery for Mac recover files from a Time Machine backup disk?
It may scan the disk, but that is not the same as a dependable Time Machine restore. If the backup is still readable, using Time Machine itself is usually simpler, faster, plus less risky.
What is a better alternative to iBoysoft Data Recovery for Mac if I need deeper recovery?
For many users, Disk Drill is the first alternative to compare. If the drive is seriously damaged, you may need a specialist service instead of consumer software, especially when the files are irreplaceable.
Does iBoysoft Data Recovery for Mac work on Apple Silicon Macs without problems?
It may run, but compatibility is only part of the story. The real question is whether it can recover what you need, plus that is where the app often falls short compared with stronger alternatives.
Should I try iBoysoft Data Recovery for Mac before going to a professional recovery lab?
If the files are not critical, a quick scan can make sense. If the data matters a lot, every extra write to the disk can lower your chances, so a recovery lab is often the safer bet.
