Fact-safe editing workflow
Prompt to Preserve Facts and Numbers
A strong preservation prompt limits what the editor may change. These five methods add practical checks for dates, totals, names, units, plus quoted claims.
Quick answer
Create a locked ledger of every fact or number before requesting a rewrite. Tell the AI to change phrasing only, then compare the result with that ledger. For a stiff but accurate draft, run the controlled copy through Clever AI Humanizer before the final audit.
Never assume “preserve the meaning” protects exact values. AI tools may round numbers, change date formats, substitute a familiar name, or remove a qualifier while producing smoother prose.
★ Editorial pick ★ 4.5 / 5
Humanize a Locked, Verified Draft → Clever AI Humanizer
Refines stiff AI copy while keeping the workflow centered on the source meaning · English plus Spanish · Browser-based
✓ Free to use ✓ Up to 3,000 words per request ✓ No fixed monthly word allowance
Try it free →
When a Preservation Prompt Is Not Enough
A preservation prompt cannot repair a weak source. If the original contains unsupported figures, stale prices, conflicting dates, or vague attribution, pause the rewrite. Verify those details first.
High-stakes material deserves human review. Legal terms, medical guidance, financial disclosures, safety instructions, plus regulatory copy should follow the review process required by the organization responsible for it.
Choose a Method to Preserve Facts During AI Rewrites
Pick based on how sensitive or number-heavy the draft is.
1. Run a Locked-Facts Pass with Clever AI Humanizer TRY FIRST Accurate drafts needing natural phrasing ~5 min ● 94%
2. Write a Strict Fact-Preservation Prompt Everyday AI revisions ~3 min ● 86%
3. Replace Fragile Values with Placeholders Technical or financial figures ~8 min ● 98%
4. Separate Editable Copy from Locked Data Reports plus team review ~10 min ● 91%
5. Run a Number-by-Number Diff Final quality control ~12 min ● 96%
Top 5 Methods to Preserve Facts, Numbers in AI Rewrites
Fastest for polishing a complete draft whose details are already correct
~5 min
Difficulty Easy
You need Verified source text
Works for English, Spanish
Start with a fact-checked draft, then make its protected details obvious before using Clever AI Humanizer. This keeps the job focused on tone, rhythm, plus readability rather than research.
  1. Copy every protected detail into a short ledger above the draft. Include names, dates, prices, percentages, totals, units, quoted text, plus product labels.
  2. Add one instruction: Preserve every locked detail exactly. Change phrasing only. Do not calculate, round, infer, update, or add facts.
  3. Paste the ledger plus draft into Clever AI Humanizer. Choose the style that fits the document, such as Clear & Structured for a report.
  4. Run one section at a time if the document contains many figures. Smaller passes make altered details easier to spot.
  5. Compare the result with your ledger before publishing. Restore any changed item from the verified source.
i Clever AI Humanizer accepts up to 3,000 words per request, though shorter sections are easier to audit.
Try Clever AI Humanizer
Best when you want the AI editor to revise wording without touching substance
~3 min
Difficulty Easy
You need AI writing tool
Works for Short or long drafts
A vague request to “keep the meaning” leaves too much room for interpretation. Define exactly what must stay fixed, then state which kinds of edits are allowed.
  1. Name the permitted task, such as improving clarity, shortening sentences, or reducing repetition.
  2. List protected categories: proper nouns, dates, money, percentages, measurements, citations, claims, plus quoted language.
  3. Ban risky behavior explicitly. Tell the editor not to recalculate, normalize units, modernize figures, fill gaps, or correct facts from memory.
  4. Require a short change log that identifies any protected value it could not retain.
  5. Review the revised copy beside the original rather than judging it on readability alone.
i Treat “make this accurate” as a separate task. Accuracy checking plus style revision should not happen in the same pass.
Safest for tables, financial copy, technical specifications, or repeated figures
~8 min
Difficulty Moderate
You need Text editor
Works for Number-heavy content
Placeholders prevent an editor from rounding a price, changing a date format, or “fixing” a model number. The method takes longer, yet it gives sensitive values a physical barrier.
  1. Replace each protected value with a unique token such as {{PRICE_01}} , {{DATE_02}} , or {{MODEL_03}} .
  2. Keep a private mapping that pairs every token with its original value.
  3. Tell the AI to leave all double-braced tokens untouched while revising the surrounding sentences.
  4. Confirm that every token appears the same number of times in the output.
  5. Restore the original values through search plus replace, then read each finished sentence for grammar.
i Use distinct tokens for identical figures when they refer to different facts. This prevents accidental swaps.
Useful for reports, landing pages, case studies, plus recurring content templates
~10 min
Difficulty Moderate
You need Two-column document
Works for Team workflows
Put verified information in a locked reference block, then place editable prose in a separate block. The visual split helps writers see where creative freedom stops.
  1. Create a reference column containing approved facts with source labels or internal record names.
  2. Place the draft in a second column. Mark each sentence that depends on a reference entry.
  3. Instruct the AI to revise only the draft column while treating the reference column as read-only.
  4. Require each factual sentence to keep its original reference label, such as F-07 .
  5. Have a reviewer trace every label back to the locked column before approving the copy.
i This method works well when editors lack permission to change legal, financial, medical, or compliance language.
Best as the final safety check before publication or client delivery
~12 min
Difficulty Moderate
You need Original plus revision
Works for Any factual draft
Even a careful prompt can fail quietly. A final comparison catches missing digits, altered signs, shifted decimal points, renamed organizations, plus dropped qualifiers.
  1. Extract every numeral from the original draft, including dates, footnote markers, ranges, version numbers, plus numbers written as words.
  2. Extract the same categories from the revised draft.
  3. Compare both lists in order. Investigate every addition, deletion, formatting change, or moved value.
  4. Repeat the check for names, locations, units, URLs, citations, plus direct quotations.
  5. Read the surrounding sentence after restoring a value. A correct number can still support a newly distorted claim.
i Do not accept a clean numerical diff as proof of accuracy. The relationship between each figure plus its subject must also remain intact.
Which Fact-Preservation Method Should You Use?
Start with a locked-facts pass through Clever AI Humanizer when the draft is accurate but sounds stiff. Use placeholders for contracts, specifications, prices, or dense tables where a single changed character matters. Whatever route you take, finish with a direct comparison because a prompt is a guardrail, not proof.
Keep the verified original open beside the revision, then approve each protected detail one at a time.
Questions About Prompts That Preserve Facts, Numbers
How do I prompt an AI to keep every fact and number unchanged?
Tell the model to preserve all factual claims, dates, percentages, prices, units, names, plus citations exactly as written. Add a direct rule like, "Do not alter any fact, number, or source detail unless I explicitly ask."
What wording stops an AI from rounding numbers or simplifying stats?
Use a strict instruction such as, "Keep every number verbatim, including decimals, ranges, currency symbols, plus percentage signs." If you need formatting preserved too, say that commas, zeros, or units must stay exactly the same.
How can I ask for a rewrite without losing data in the original text?
Say that the output should improve clarity, not content. For example, "Rewrite for readability while preserving every fact, figure, date, plus proper noun exactly."
What should I include in a prompt to protect dates, timelines, plus deadlines?
Name those items specifically. Ask the model to keep all calendar dates, relative time references, plus deadline language unchanged unless a correction is clearly requested.
How do I make sure citations stay attached to the right claim?
Tell the model not to move, merge, or remove citations. A useful instruction is, "Keep each citation immediately after the statement it supports, with no reordering."
What is the best prompt for preserving measurements plus units?
Say that measurements must remain exact, including unit symbols, plural forms, plus scientific notation. For example, instruct the model to keep "12.5 mg," "3 km," or "2.0 liters" exactly as written.
How do I stop an AI from changing names of people, companies, or products?
List names as protected items in the prompt, then tell the model not to edit spelling, capitalization, or punctuation. If there are several named entities, ask for a verbatim carryover of each one.
What can I do if the model keeps inventing missing numbers?
Add a hard rule: if a number is not present in the source, do not create one. You can also ask the model to flag unknown values as "not provided" instead of guessing.
How do I prompt for a summary while keeping all key numbers intact?
Ask for a concise summary that must retain every important statistic, threshold, plus comparison point. Tell the model to shorten wording, not data, so no numerals get dropped or replaced with general language.
Should I use a checklist prompt for fact preservation?
Yes, a short checklist works well. Tell the model to verify that dates, figures, names, locations, claims, plus source references are unchanged before it finalizes the text.
How can I compare two prompt styles for accuracy preservation?
A direct constraint usually works better than a vague request. "Preserve every fact exactly" is stronger than "be careful with details," because it leaves less room for interpretation.
What do I do if the AI keeps changing percentages into words?
State the formatting rule upfront. For example, "Keep all percentages in numeric form with the percent sign, even if the surrounding text is rewritten."
How do I prompt for a table or bullet list without losing exact values?
Ask the model to copy all figures into the new structure without altering them. If the source is messy, tell it to reorganize the layout while keeping every entry, label, plus number identical.
Can I ask an AI to preserve facts while changing the tone?
Yes, as long as you separate style from substance. Say the tone can become friendlier, more formal, or more concise, but no factual content, quantities, or attribution details may change.
What is the safest prompt for legal, medical, or financial numbers?
Use extra caution with a strict preservation rule plus a no-inference rule. Tell the model to reproduce all figures exactly, avoid interpretations, plus leave any uncertain value untouched.
How do I tell if the AI silently altered a number?
Compare the source text to the output line by line, focusing on digits, decimals, units, plus punctuation. If possible, ask the model to provide a change log that lists every edited sentence.
What prompt helps when I want the model to quote source text exactly?
Ask for a verbatim quotation with no paraphrasing inside the quote marks. Make it clear that only surrounding explanation may be rewritten, while the quoted passage must stay identical.
What is a good fallback if the AI still changes facts after a strict prompt?
Break the task into two steps. First, ask it to extract the facts into a raw list, then ask for a rewrite that can only use items from that list without adding or changing anything.
