Tested on two drives plus an SD card
Stellar Data Recovery for Mac: Honest Review and Alternatives in 2026
Stellar found plenty of files, yet too many came back damaged, unnamed, or buried in messy results. Disk Drill produced cleaner recoveries in the same tests.
5.8 /10
Usable, Yet Hard to Recommend Uneven recovery, cluttered results, awkward pricing
Not recommended
Stellar Data Recovery for Mac recovered some ordinary deleted files, but its weaker SD card results, slower deep scan, plus confusing feature tiers got in the way. Disk Drill is the better alternative for clearer previews, stronger recovery results, plus a simpler $89 personal license.
Do not install Stellar on the same drive that lost the files, since new writes can overwrite recoverable data before scanning begins.
Stellar Data Recovery for Mac at a Glance
5.8/10
Stellar is a macOS utility for scanning deleted, formatted, lost, or inaccessible storage. Higher editions add disk imaging, crashed-Mac recovery, plus media repair.
Best forMac users handling a simple deletion where Stellar's preview already shows the exact files intact
  • Quick plus deep scanning
  • APFS, HFS+, exFAT, plus removable-drive support
  • File preview before recovery
  • Saved scan sessions
  • Photo or video repair on Premium
Pricing Free scan plus preview · Standard $69.99/year · Professional $89.99/year · Premium $99.99/year
Standout featureA straightforward scan wizard that requires little technical setup
  • Easy first scan
  • Broad file-format support
  • Pause plus resume option
  • Weak value across annual tiers
  • Messy deep-scan output
  • Disk Drill recovered more usable test files
How Stellar Data Recovery for Mac Scored Across Our Tests
01 Recovery Results
5.8/10
02 Scan Workflow
7.2/10
03 Result Quality
4.9/10
04 Mac Experience
6.3/10
05 Cost, Licensing
4.7/10
How We Tested Stellar Data Recovery for Mac Against Disk Drill
We ran both apps on the same Apple silicon Mac using a 500 GB APFS test image, a freshly formatted exFAT SD card, plus a mixed folder containing JPEG, RAW, MOV, MP4, PDF, DOCX, ZIP, plus spreadsheet files. Each app scanned a fresh copy of the source image so one run could not alter the other.
A file counted as recovered only if it opened fully, matched the expected size, plus remained usable beyond a thumbnail or partial preview. We also recorded scan time, folder structure, retained names, preview behavior, license terms, plus one support exchange.
When to Avoid DIY Mac Recovery Software
Do not keep scanning a drive that clicks, disconnects, disappears from Disk Utility, or reports rapidly growing hardware errors. Repeated reads can make a failing disk worse. Shut it down, then contact a recovery lab if the files cannot be replaced.
DIY tools are also poor bets for a modern Mac SSD after TRIM has cleared deleted blocks. FileVault encryption, physical NAND damage, liquid exposure, plus a dead controller may require specialist work or may make recovery impossible.
Stellar Data Recovery for Mac Recovery Performance in Detail
Recovery Results
Adequate for simple deletion, less convincing after formatting
5.8/10
Stellar handled recently deleted documents reasonably well, especially where file-system records were still present. Trouble started with a formatted SD card plus an external SSD image. Across our recoverable test set, it restored 42% from the SSD scenario plus 71% from the SD card as usable files.
The raw number of files found looked encouraging at first. After opening the output, though, several videos were incomplete, while reconstructed files often lost their original names or folder paths. Disk Drill returned more usable media from both sets.
  • Found recently deleted office files quickly
  • Supports APFS, HFS+, exFAT, plus common removable media
  • Can save a scan for later review
  • Professional tier includes disk-image creation
  • Several recovered videos would not play fully
  • Formatted-media results trailed Disk Drill
  • Large result counts overstated the usable recovery
Scan Workflow
The strongest part of Stellar's Mac app
7.2/10
The basic flow is easy to follow. Pick the data type, choose a volume, then start scanning. Stellar also lets you pause a scan, resume it later, or inspect files while work continues. Our 500 GB quick scan took 8 minutes, which was acceptable but slower than Disk Drill's run.
Controls become less tidy once thousands of reconstructed files appear. Filters help, though locating one missing project can still mean opening many generic folders with names that provide little context.
  • Simple device selection screen
  • Pause plus resume controls
  • Preview available before recovery
  • Saved scans avoid repeating lengthy work
  • Filters do not fully tame large raw-scan result sets
  • Too many generic folders after signature-based recovery
Result Quality
Too many found files were damaged or hard to identify
4.9/10
This was Stellar's biggest weakness. A successful scan is not the same as a successful recovery. We checked photos at full resolution, opened documents, then played videos past their first few seconds. That removed a sizable group of false positives plus partial files from the usable total.
File names survived in straightforward deletion cases. Deep-scan output was much rougher, with recovered media sorted into broad type folders. Disk Drill preserved more useful context in our file-system recovery test, which reduced the time spent opening mystery files.
  • Preview catches some corrupt files before payment
  • File-type filters cover common Mac formats
  • Healthy JPEG files generally opened without extra work
  • Too many partial files appeared recoverable at first glance
  • Original names disappeared in several deep-scan results
  • Recovered video quality was inconsistent
Mac Experience
Functional on modern Macs, though not especially polished
6.3/10
Stellar ran on our Apple silicon Mac after Full Disk Access was granted. The main recovery screens were readable, plus device detection worked without manual setup. Still, the app felt less settled than Disk Drill once we moved beyond the first scan.
Upsell cues remain visible even on paid tiers. Features such as crashed-system recovery, lost-volume recovery, photo repair, or video repair are split across higher editions. That makes it easy to start with Standard only to discover that the useful feature for your situation sits in Professional or Premium.
  • Apple silicon support
  • Clear permission instructions
  • Recognized the tested USB drive plus SD card reader
  • Works with common Mac file systems
  • Recovery features are divided across several editions
  • Persistent upgrade cues make the paid app feel unfinished
  • Result navigation gets cumbersome on large scans
Cost, Licensing
Too many editions for a tool bought during an emergency
4.7/10
Stellar lists Standard at $69.99 for one year, Professional at $89.99 for one year, plus Premium at $99.99 for one year. Standard covers basic recovery, while Professional adds lost-volume, crashed-Mac, plus disk-image tools. Premium adds photo or video repair.
The free download is mainly useful for scanning plus previewing. Payment is needed for ordinary recovery. Disk Drill also limits normal Mac recovery in its free edition, but its $89 personal PRO license is easier to understand, covers unlimited personal recovery, plus can be purchased as a perpetual license.
  • Free scanning helps confirm whether files appear
  • Three paid levels let buyers avoid repair tools they do not need
  • Standard includes unlimited recovery during its license term
  • Free edition does not provide general unlimited recovery
  • Useful disk-image features require Professional
  • Annual tiers are poor value for occasional emergencies
Free $0 Scan plus preview only for normal unprotected files
Standard $69.99 One-year basic recovery license
Professional $89.99 One year with lost-volume plus disk-image tools
Premium $99.99 One year with photo plus video repair
Stellar Data Recovery for Mac vs Disk Drill — Head to Head
Identical hardware, identical test scenarios. Here is how they compared.
Metric Stellar Data Recovery for Mac Disk Drill
SSD recovery rate 42% 67%
SD card recovery 71% 89%
Quick scan time (500 GB) 8 min 5 min
Deep scan time (500 GB) 96 min 74 min
Free recovery limit Preview only Protected files
License model 1-year $89.99 One-time $89
Email support response ~31 hours ~9 hours
Overall score 5.8 / 10 8.7 / 10
What to Use Instead
Disk Drill is our pick for Mac owners who want better recovery output without sorting through as many broken or anonymous files.
Disk Drill for Mac
A clearer recovery workflow with stronger test results
8.7/10
Disk Drill recovered more usable files in every shared scenario, while its previews, recovery-chance labels, plus cleaner result tree made the output easier to check. It was particularly better with our formatted SD card, where more photos kept useful metadata plus more video clips played from start to finish.
The Mac free edition scans plus previews ordinary recoverable data before purchase. Normal Quick Scan or Deep Scan recovery needs PRO unless the files were protected earlier through Guaranteed Recovery. The personal PRO edition costs $89, with a perpetual-license option plus support for up to three Macs owned by one user.
Why We Recommend It
  • Higher usable-file recovery in both shared tests
  • Faster quick plus deep scans
  • Clear previews before buying
  • Byte-to-byte backup tool helps reduce risk on unstable media
  • One personal license covers up to three Macs
Caveats
  • General Mac recovery is not free
  • A perpetual license may cost more than a short subscription at checkout
  • No software can reverse SSD data loss after TRIM clears the blocks
Basic $0 Scan, preview, plus free recovery of protected files
PRO $89 Unlimited personal recovery with perpetual-license option
Disk Drill Review ↗ Download Disk Drill
What Users Report About Stellar Plus Disk Drill
A Macworld tester liked Stellar's deep recovery tools, though the junk-cleaning module repeatedly crashed. The review also noted activation trouble plus persistent upgrade prompts after purchase.
Chris Barylick · Macworld
A reviewer said Stellar's software worked, though undeleting files took time. Support resolved the issue when help was needed.
Trustpilot reviewer · Trustpilot
One Reddit user recovered photos from an inaccessible SD card with Disk Drill after other tools failed to detect or properly reconstruct the files.
Decent-Strawberry-97 · r/DataRecoveryHelp
A later commenter in the same thread reported paying for Disk Drill after a scan, then finding that the needed client files could not actually be recovered. It is a useful reminder to preview critical files first.
Should You Buy Stellar Data Recovery for Mac?
Stellar Data Recovery for Mac is acceptable for simple deleted-file jobs where the free preview clearly opens what you need. It fell short in our formatted-media tests due to lower usable recovery, untidy raw results, plus paid features split across several editions.
Most home Mac users should skip it. Download Disk Drill first, scan the drive, preview several important files from beginning to end, then pay only if the results look intact.
Stop using the affected drive, create a byte-to-byte image if the hardware seems unstable, then recover files to a different physical disk.
Stellar Data Recovery for Mac Questions, Answered
Is Stellar Data Recovery for Mac worth using in 2026 if I only need to recover a few deleted files?
Usually no. The free scan is fine for checking what is still recoverable, but the paid version feels overpriced if you only need one small restore job.
Why does Stellar Data Recovery for Mac take so long to scan large drives?
Deep scans can run slowly, especially on older Macs or near full external drives. If time matters, a simpler tool like EaseUS Data Recovery Wizard for Mac may feel less frustrating.
Can Stellar Data Recovery for Mac recover files from an APFS drive after a format?
Sometimes, but results are inconsistent. If the format was recent, stop using the drive right away because every new write lowers the chance of recovery.
What are the biggest problems people run into with Stellar Data Recovery for Mac?
The most common complaints are slow scans, a cluttered interface, limited preview quality, plus recoverable files that still fail to open. The app can feel more complicated than it should for a basic recovery task.
How does Stellar Data Recovery for Mac compare with Disk Drill on Mac?
Disk Drill is usually easier to navigate plus feels more polished. Stellar can still find lost files, but many users prefer Disk Drill when they want a faster, cleaner workflow.
Is the free version of Stellar Data Recovery for Mac enough to actually restore files?
No, not really. The free version is mostly a scanner, so you will need a paid license before you can finish most recoveries.
What should I do if Stellar Data Recovery for Mac freezes during a scan?
Quit the app, restart your Mac, then disconnect any unnecessary external devices before trying again. If it keeps freezing, the drive itself may be unstable, so try a different recovery tool sooner rather than later.
Does Stellar Data Recovery for Mac work well on M1, M2, plus M3 Macs?
It usually installs, but compatibility does not always mean smooth performance. Some users still report lag, odd behavior, or long waits that make it feel less optimized than newer competitors.
Is Stellar Data Recovery for Mac safe to use on a drive with important business files?
It is generally safe if you install it on a different drive, not the one you want to recover. The bigger risk is delay, since repeated scans can waste valuable time when the drive is failing.
What is a better alternative to Stellar Data Recovery for Mac if I want a simpler app?
For many people, Disk Drill is easier to understand, while R-Studio is stronger for technical recovery cases. If you want a less annoying first try, Disk Drill is the more approachable option.
Can Stellar Data Recovery for Mac recover files from an encrypted Time Machine backup?
Only if the backup is readable plus you have the password. If the backup structure is damaged, success drops fast, so it is not the tool I would trust for a delicate Time Machine job.
Why are the recovered files from Stellar Data Recovery for Mac damaged or unreadable?
That usually means the file fragments were overwritten or the original metadata is gone. Recovery software can only rebuild what is still present, so a successful scan does not guarantee a usable file.
How much does Stellar Data Recovery for Mac cost in 2026?
Pricing changes often, so check the current plan page before buying. In practice, many users feel the cost is hard to justify when other Mac recovery apps offer similar results for less.
Can I use Stellar Data Recovery for Mac on an external SSD or USB drive?
Yes, but scan the drive from your Mac, not from the same external device you are trying to rescue. If the external drive is physically failing, the software may struggle no matter which device it runs from.
Does Stellar Data Recovery for Mac preview photos, videos, plus documents accurately?
Preview support exists, but it is not always reliable with heavily damaged files. If previews matter to you, test the free scan first because that can save you from paying for a poor match.
What should I choose instead of Stellar Data Recovery for Mac if I need advanced recovery?
R-Studio is the better pick for deeper control, especially on complex disk problems. It is less beginner friendly, but it tends to be more trustworthy for serious recovery work.
Is Stellar Data Recovery for Mac a good choice for beginners in October 2026?
Not really. It can recover files, but the experience feels clunky enough that beginners often get better results faster with a more polished alternative like Disk Drill or EaseUS.
