Mac startup recovery · August 2026
What to Do with an Accidentally Deleted Startup Disk on Mac (Macintosh HD)?
Deleting Macintosh HD is not the same as deleting one file. The right next step depends on whether you need unbacked-up data, have Time Machine, or cannot see the internal device at all.
Quick answer
Turn the Mac off if you need unbacked-up files. Try Disk Drill from macOS Recovery before recreating Macintosh HD, or restore from Time Machine if you have a recent backup. Reinstall macOS only after file recovery is finished.
Do not recreate Macintosh HD, reinstall macOS, or install recovery software on the affected internal storage before attempting file recovery. Those writes can replace deleted data. SSD recovery may already be limited by TRIM.
★ Editorial pick ★ 4.4 / 5
Recover Unbacked-up Macintosh HD Files → Disk Drill
Runs from macOS Recovery · Scans internal APFS storage · Previews found files before recovery · Saves recovered data to external storage
✓ Free scan plus preview ✓ Apple silicon support ✓ Recovery Mode option
Try the free scan →
Choose the Right Macintosh HD Recovery Method
Start with the row that matches your backup status plus what Disk Utility can still see.
1. Recover Macintosh HD Files with Disk Drill TRY FIRST Unbacked-up personal files ~30 min ● 55%
2. Restore the Mac from Time Machine Recent complete backups ~1–4 hr ● 95%
3. Recreate Macintosh HD and Reinstall macOS Returning the Mac to service ~45–120 min ● 90%
4. Access the Startup Disk from Another Mac Copying surviving accessible files ~20–90 min ● 70%
5. Escalate a Missing or Failing Internal Disk Disk absent or Recovery broken ~1–7 days ● 35%
How to Tell What Was Actually Deleted from Your Mac
If Macintosh HD disappeared but the physical SSD plus APFS container remain in Disk Utility, you may have removed only a volume. If the entire internal device is missing, the cause may be firmware trouble, storage failure, or a logic-board issue rather than an accidental click.
Choose View > Show All Devices before deciding. The indented Macintosh HD entry is a volume. The top-level entry represents the physical storage device.
When Not to Keep Scanning an Erased Mac SSD
Stop if the drive disconnects during scans, makes unusual noises on an older hard-drive Mac, or produces repeated I/O errors. Continued scanning can stress failing hardware.
Also reconsider DIY recovery when the lost files are legally sensitive, hold the only copy of paid client work, or justify professional recovery costs. A software scan is not harmless if the storage hardware is unstable.
Top 5 Ways to Recover an Accidentally Deleted Mac Startup Disk
Best first move when personal files matter more than getting the Mac running quickly
~30 min
Difficulty Moderate
You need Internet, external drive
Works for Apple silicon, Intel Mac
Use this route before reinstalling macOS if the deleted startup disk held files with no backup. Running Disk Drill from macOS Recovery limits extra writes to the internal storage, though an SSD that has already processed TRIM may yield few recoverable files.
  1. Shut down the Mac. Do not reinstall macOS, recreate volumes, or save anything to its internal storage yet.
  2. Start macOS Recovery. On Apple silicon, hold the power button until startup options appear, then choose Options. On an Intel Mac, turn it on while holding Command-R .
  3. Connect a separate external drive with enough free space for recovered files.
  4. Follow the official Disk Drill Recovery Mode instructions, then allow the requested disk access.
  5. Select the internal physical device or lost APFS container, then run Search for lost data. Preview important files before committing to recovery.
  6. Recover selected files to the external drive only. Never choose the damaged or deleted Macintosh HD as the destination.
Disk Drill Review ↗
i If the internal device is absent from Disk Utility even after choosing View > Show All Devices, skip software scans plus consider Method 5.
Read the Disk Drill Recovery Mode guide
Cleanest option when a recent complete backup exists
~1–4 hr
Difficulty Easy
You need Time Machine backup
A Time Machine restore can rebuild the Mac from a dated backup instead of trying to undelete individual blocks. Expect changes made after that backup to be missing unless another copy exists in iCloud, email, or external storage.
  1. Connect the Time Machine backup disk directly to the Mac, plus connect the power adapter if it is a notebook.
  2. Enter macOS Recovery using the power-button method for Apple silicon or Command-R for an Intel Mac.
  3. Choose Restore from Time Machine, then select the correct backup source.
  4. Pick the newest backup created before Macintosh HD was deleted. Check its date carefully rather than choosing the first entry.
  5. Select the recreated internal destination when prompted, then leave the Mac connected to power until restoration finishes.
i If Recovery cannot offer a suitable destination, recreate Macintosh HD with Method 3 before restoring your files during Setup Assistant.
Read Apple’s Time Machine restore instructions
Fastest route back to a working Mac when recovery is complete or no lost files are needed
~45–120 min
Difficulty Moderate
You need Internet connection
This does not undelete the old volume. It creates a fresh APFS startup volume, writes a new macOS installation, then lets you restore available data from backups or cloud services.
  1. Do this only after finishing data-recovery attempts. Every new write can overwrite deleted content.
  2. Open macOS Recovery, launch Disk Utility, then choose View > Show All Devices.
  3. Select the internal physical device or its APFS container. Do not erase an unrelated external backup disk.
  4. Click Erase. Use Macintosh HD as the name plus APFS as the format. Choose Erase Volume Group if that button appears.
  5. Quit Disk Utility, choose Reinstall macOS, then install onto the newly created Macintosh HD.
  6. During setup, transfer data from Time Machine if available. Otherwise finish setup as a new Mac, then copy recovered files back later.
i If Disk Utility sees the hardware but cannot erase it, run First Aid once. Repeated erase attempts offer little value when the device reports hardware errors.
Read Apple’s macOS reinstall guide
Useful when Recovery opens plus the remaining volume can still be unlocked
~20–90 min
Difficulty Moderate
You need Second Mac, proper cable
A second Mac gives you somewhere safe to copy files without installing software on the affected startup disk. Apple silicon uses Share Disk from Recovery, while Intel models can use Target Disk Mode.
  1. Connect both Macs using a compatible USB-C or Thunderbolt cable. A charging-only cable will not carry disk data.
  2. For Apple silicon, enter Recovery, choose Utilities > Share Disk, select an available volume, then click Start Sharing. For Intel, start the affected Mac while holding T .
  3. On the healthy Mac, open Finder, locate the connected Mac under Network or Locations, then choose Connect As if shown.
  4. Unlock the volume with the affected Mac’s account password or recovery key.
  5. Copy visible personal files to storage attached to the healthy Mac. Do not copy anything onto the affected internal disk.
  6. If ordinary Finder access fails but the device mounts, run Disk Drill on the healthy Mac for an Intel target. For Apple silicon deep scanning, use Disk Drill directly in Recovery on the affected Mac.
i Share Disk copies existing accessible files. It is not a deleted-file scan on Apple silicon.
Read Apple’s Mac-to-Mac transfer guide
Last resort when Disk Utility cannot detect the physical device or Recovery will not load
~1–7 days
Difficulty Advanced
You need Second Mac or repair service
Works for Recent supported Macs
If the physical internal device disappears from Disk Utility, software cannot scan storage that macOS cannot address. A firmware revive may fix a startup or Recovery problem without erasing data, while a firmware restore deliberately erases the Mac.
  1. Disconnect nonessential accessories, restart into Recovery, then check Disk Utility > View > Show All Devices one final time.
  2. If Recovery itself is unavailable on a supported Apple silicon or T2 Mac, connect it to another compatible Mac with a data-capable USB-C cable.
  3. Follow Apple’s DFU instructions for the exact model, then choose Revive Mac first. A revive is intended not to erase the Mac.
  4. Do not choose Restore Mac if unbacked-up files remain important. Restore erases the computer before returning it to factory condition.
  5. If the disk stays missing, powers off, or reports repeated I/O errors, stop DIY attempts. Ask a data-recovery lab whether the model’s soldered, encrypted storage leaves any viable recovery path.
i Apple silicon plus T2 storage is encrypted. Without the original hardware keys or an unlock credential, chip-level recovery may be impossible.
Read Apple’s firmware revive instructions
Which Macintosh HD Recovery Method Should You Use?
Disk Drill from macOS Recovery is the sensible first attempt when Macintosh HD contained irreplaceable files with no backup. Use Time Machine instead when a recent backup covers what was lost. Once the data question is settled, recreate Macintosh HD plus reinstall macOS to make the computer bootable again.
If the physical device never appears in Disk Utility, stop treating this as a deleted-volume problem. Try a non-erasing firmware revive or move the case to a qualified repair or recovery service.
Recover or copy important files to an external disk first, verify several of them on another Mac, then rebuild Macintosh HD.
Macintosh HD Deletion Questions, Answered
How do I tell if I deleted Macintosh HD or just removed it from Finder on my Mac?
Open Disk Utility from Recovery or macOS Utilities, then look for an internal APFS container or volume named Macintosh HD. If it still appears there, the disk was not fully erased, so you may just need to mount it or reinstall macOS.
What should I do first after accidentally deleting my startup disk on a Mac?
Stop using the Mac right away so you do not overwrite recoverable data. Then shut it down, boot into macOS Recovery, and check whether the disk still appears in Disk Utility before trying any repair step.
Can I recover a deleted Macintosh HD without erasing my Mac again?
Sometimes, yes. If the disk still exists in Disk Utility, you may be able to run First Aid, mount the volume, or reinstall macOS over it without wiping the drive.
How do I open Disk Utility from macOS Recovery on an Intel Mac or Apple silicon Mac?
On an Intel Mac, restart then hold Command-R until Recovery appears. On Apple silicon, shut down, hold the power button until startup options show up, then choose Options and continue into Recovery.
What does it mean if Disk Utility shows the drive but not Macintosh HD?
That usually means the physical drive is fine but the startup volume is missing, damaged, or renamed. In that case, you may need to recreate the volume structure or reinstall macOS onto the available container.
Is it safe to use First Aid after deleting the startup disk?
Yes, if the internal disk still shows up in Disk Utility. First Aid can fix file system problems, but it will not bring back data from a drive that was truly erased.
How do I reinstall macOS if Macintosh HD is gone?
Boot into Recovery, connect to Wi-Fi, then choose Reinstall macOS from the Utilities window. If Disk Utility still lists the internal drive, select it as the install target, then follow the prompts.
What if my Mac only shows Recovery Assistant after the startup disk was deleted?
That usually points to a missing boot volume or a deeper startup issue. Go back to Disk Utility, check for the internal disk, then use Reinstall macOS if the hardware is still detected.
Can I recover files from a deleted startup disk with Time Machine?
Yes, if you have a Time Machine backup from before the deletion. After reinstalling macOS, open Migration Assistant or the Time Machine restore interface to bring your apps, files, settings back.
What is the difference between deleting Macintosh HD volumes and erasing the whole disk?
Deleting a volume removes that APFS volume, while erasing the whole disk removes the container plus all volumes on it. Erasing the whole disk is more destructive, so recovery options are usually more limited.
How do I know if I need Apple Support after deleting my startup disk?
If Disk Utility cannot see any internal storage, the Mac may have a hardware problem instead of a software issue. In that case, contact Apple Support or book a Genius Bar appointment before trying more repairs.
Can I use another Mac to restore a deleted startup disk on my MacBook?
Sometimes you can use another Mac with Apple Configurator for DFU revive or restore on supported Apple silicon models. This is more advanced, so follow Apple's recovery steps carefully before you erase anything else.
What are the signs that the internal drive is still healthy after the deletion?
If Disk Utility can mount the drive, run First Aid, and show the correct physical capacity, that is a good sign. A healthy drive should also appear consistently across restarts in Recovery.
How do I avoid deleting Macintosh HD again while erasing an external drive?
In Disk Utility, turn on View then Show All Devices so you can see the full drive hierarchy. Always select the external physical disk by its manufacturer name, not the internal Apple SSD or its volumes.
What should I do if my Mac starts to a blinking question mark after the startup disk was deleted?
That means the Mac cannot find a bootable system. Start in Recovery, check whether the internal disk is present, then reinstall macOS or restore from backup if the drive still exists.
Are third-party Mac data recovery tools worth trying after deleting Macintosh HD?
They can help only if the drive was not overwritten and the Mac can still access the storage device. Use caution, since a bad recovery attempt can reduce the chance of getting files back.
How much does it cost to fix a deleted startup disk on a Mac?
If the disk is intact, the fix may cost nothing beyond your time because Recovery and macOS reinstall are free. If the internal drive failed or needs service, the cost depends on your model, warranty coverage, and whether data recovery is possible.
