Mac storage recovery · August 2026
How to Recover Deleted Partition on Mac?
A deleted partition is recoverable only while its old data remains untouched. Start with the physical disk, save recovered files elsewhere, plus avoid rebuilding the volume too early.
Quick answer
Stop using the affected disk, then scan its physical device with Disk Drill. Preview the found files before paying or recovering, then save everything to another drive. Use Time Machine instead if you already have a clean backup from before the partition vanished.
Do not erase, repartition, reinstall macOS, or create a new volume on the affected space. Those actions can overwrite the partition metadata or file contents you are trying to recover. If the disk clicks or disconnects, power it off.
★ Editorial pick ★ 4.5 / 5
Scan a Deleted Mac Partition → Disk Drill
Searches the full physical disk · Previews found files before recovery · Runs on macOS plus Windows
✓ Free scan plus preview ✓ Byte-to-byte backup tool ✓ APFS plus HFS+ support
Scan the disk →
Top 5 Ways to Recover a Deleted Partition on Mac
Scan the Lost Partition With Disk Drill
Best first move when the physical disk still appears in Disk Utility
~15 min
Difficulty Easy
You need Disk Drill plus a second drive
Works for APFS, HFS+, exFAT, FAT32, NTFS
Disk Drill can search the whole physical device for lost partition data, even if the missing volume no longer mounts in Finder. Use this route before creating a replacement partition or erasing anything.
  1. Stop saving files to the affected disk. If it is external, disconnect it until you are ready to begin.
  2. Install Disk Drill on a different disk, never the device holding the deleted partition.
  3. Open Disk Drill, grant the requested macOS permissions, then select the physical device rather than a surviving volume beneath it.
  4. Click Search for lost data. Let every scan finish, since the lost partition may appear later in the process.
  5. Open the found partitions or review reconstructed files. Preview several important items to check whether they are readable.
  6. Select the files you need, click Recover, then save them to a separate healthy drive.
Disk Drill Review ↗
i A working preview is more useful than a filename alone when judging whether a file survived intact.
Open the Disk Drill website
Restore the Missing Files From Time Machine
Safest choice when a backup predates the partition loss
~20 min
Difficulty Easy
You need A usable Time Machine backup
Works for Personal files, apps, user accounts
Time Machine will not normally recreate a deleted partition entry by itself. It can put the files back onto a new healthy volume, which is usually what matters.
  1. Connect the Time Machine backup disk without erasing or reformatting the affected device.
  2. Create a new volume on a different healthy disk if you need a destination for the restored files.
  3. Open the folder where the missing files originally lived, then launch Time Machine through Spotlight.
  4. Move through the backup timeline to a date before the partition disappeared.
  5. Select the needed folders or files, then click Restore.
  6. For a full user-account recovery, open Migration Assistant from Applications > Utilities, then choose the Time Machine option.
i Check the date of the selected backup before restoring. A newer snapshot may already reflect the deletion.
Read Apple's Time Machine restore instructions
Run First Aid in Disk Utility
Useful when the partition is present but damaged, unmounted, or missing from Finder
~10 min
Difficulty Easy
You need Disk Utility
Works for Volumes with logical file-system errors
A volume can look deleted when its file system is damaged or macOS simply failed to mount it. First Aid may restore access, but it cannot undelete a partition entry that has truly been removed.
  1. Open Disk Utility from Applications > Utilities.
  2. Choose View > Show All Devices so the physical disk, containers, plus volumes are visible.
  3. Look for a dimmed volume beneath the affected device. Select it, then click Mount once.
  4. If it will not mount, select the volume, click First Aid, then confirm with Run.
  5. Repeat First Aid upward through the storage structure, starting with the volume, then its container, then the physical device.
  6. If the volume mounts, copy important files to another disk before doing further repairs.
i Skip First Aid if the disk clicks, disconnects, stalls, or reports severe hardware errors.
View Apple's Disk Utility repair guide
Rebuild the Partition Entry With TestDisk
Advanced option for an exact partition match on a stable drive
~30 min
Difficulty Advanced
You need TestDisk plus Terminal
Works for Supported partition maps, HFS+, FAT, exFAT
TestDisk can search a disk for old partition boundaries, then write a recovered entry back to the partition table. A wrong selection can make the layout worse, so recover files first whenever possible.
  1. Create a sector-level image of the affected disk if you have enough storage. Work from that image rather than the original when possible.
  2. Download TestDisk from the official CGSecurity site, extract it, then open Terminal in its folder.
  3. Run sudo ./testdisk , choose Create for the log, then select the affected physical disk.
  4. Accept the detected partition-table type unless you know it is incorrect. Choose Analyse, followed by Quick Search.
  5. Highlight a found partition, press P to list its files, then verify names plus folder contents. Use Deeper Search if the correct layout is absent.
  6. Choose Write only if the start position, size, file listing, plus neighboring partitions match the old layout exactly. Restart the Mac afterward.
i Do not write a guessed layout. Exit TestDisk if you cannot clearly identify the original partition.
Read the official TestDisk partition recovery guide
Send the Drive to a Recovery Lab
Right choice for unstable hardware or irreplaceable data
1–10 days
Difficulty Low effort
You need A professional recovery service
Works for Failing HDDs, damaged enclosures, unstable SSDs
DIY scans are a poor gamble when a disk clicks, repeatedly disappears, runs extremely slowly, or contains the only copy of critical work. A recovery lab can image unstable media with equipment unavailable in normal Mac software.
  1. Power off the drive or Mac. Do not keep reconnecting it to see whether it works this time.
  2. Write down what happened, including any erasure, partition change, fall, liquid exposure, noises, or repair attempts.
  3. Contact a lab that offers an evaluation plus a written quote before recovery begins.
  4. Ask whether the lab performs the work in-house, whether opening an HDD is done in a controlled clean environment, plus how recovered data is returned.
  5. Pack an external drive in an anti-static bag with firm padding. For a MacBook with soldered storage, send the whole computer if the lab requests it.
  6. When the recovered files arrive, open a sample from each important folder before approving the result.
i Physical damage does not improve with repeated software scans. Each extra power cycle may reduce the readable area.
How to Tell Whether the Mac Partition Is Deleted or Merely Unmounted
Open Disk Utility, then choose View > Show All Devices. If the volume appears beneath its container but is gray, try mounting it before treating it as deleted. If only empty space appears where the volume used to be, the partition entry may be gone.
If the physical device itself is missing, test another cable, port, enclosure, or Mac. Software cannot scan storage that macOS never detects.
When to Stop DIY Mac Partition Recovery
Stop if an HDD clicks, spins down repeatedly, or vanishes during reads. The same rule applies to an SSD or USB device that becomes unusually hot, disconnects, or reports the wrong capacity.
Also pause if FileVault encryption is involved but you lack the password or recovery key. A scan may locate encrypted sectors without producing usable files.
Choose a Mac Partition Recovery Method
Pick based on whether the problem is deletion, corruption, backup loss, or failing hardware.
1. Scan the Lost Partition With Disk Drill TRY FIRST A deleted volume on a readable disk ~15 min ● 82%
2. Restore the Missing Files From Time Machine Files covered by an older backup ~20 min ● 95%
3. Run First Aid in Disk Utility A present volume that will not mount ~10 min ● 65%
4. Rebuild the Partition Entry With TestDisk Recovering a verified partition boundary ~30 min ● 58%
5. Send the Drive to a Recovery Lab Unstable or physically damaged storage 1–10 days ● 72%
Which Mac Partition Recovery Method Should You Use?
Start with Disk Drill when the device is stable, visible in Disk Utility, plus missing its old partition. It lets you scan the physical disk, inspect found partitions, then preview files before copying them elsewhere. Choose Time Machine when a backup already contains the lost data, First Aid for a volume that still exists but will not mount, or a recovery lab for unstable hardware.
Recover the files to a separate disk before attempting to recreate, resize, or repair the missing partition.
Mac Deleted Partition Recovery Questions
How do I recover a deleted partition on Mac without wiping the whole drive?
Start by stopping all writes to that disk, then use Disk Utility or a partition recovery tool to scan the drive for lost partition entries. If the partition table is damaged, recovery software can often restore the missing partition map without erasing the rest of the disk.
Can I recover a deleted partition on Mac using Disk Utility alone?
Sometimes, if the partition is only hidden or the table is mildly damaged. If Disk Utility only shows the disk as free space or missing volume structures, you will usually need dedicated recovery software or a disk image workflow.
What should I do first after deleting a partition on my Mac?
Stop using the Mac right away so new files do not overwrite the deleted partition data. If possible, disconnect the drive, then work from another Mac or boot volume to reduce the risk of permanent loss.
Is it safe to run First Aid after a partition is deleted?
Only if you are trying to repair a clearly intact disk structure on a secondary drive. If the partition was deleted by mistake, First Aid can sometimes change metadata in ways that make recovery harder, so it is usually better to scan the disk with recovery software first.
How do I tell the difference between a deleted partition and a deleted volume on Mac?
A deleted volume may still leave the partition in place, while a deleted partition removes the section from the partition map entirely. Disk Utility may show unallocated space for a deleted partition, while a deleted volume can sometimes still appear in recovery scans.
Can I recover a deleted APFS partition on Mac?
Yes, if the APFS container or its metadata has not been overwritten. APFS containers can be rebuilt or detected during a deep scan, then the files can often be copied out or the partition can be restored.
What is the best Mac partition recovery software for an internal SSD?
Look for a tool that supports APFS, HFS+, Intel Macs, Apple silicon Macs, plus deep scan recovery from unallocated space. The best choice is one that can preview files before recovery so you do not waste time restoring the wrong data.
How much does it cost to recover a deleted partition on Mac?
Software recovery is often cheaper than professional recovery, with many tools offering a limited free scan plus a paid recovery license. If the drive is physically damaged, professional help can cost much more because it may require lab work.
Can I recover a deleted partition from an external hard drive on Mac?
Yes, external drives are often easier to recover because you can scan them from the Mac without booting from the same drive. Just make sure the drive stays disconnected from normal use until the scan is complete.
What if Disk Utility says the partition is gone but the files still show up in recovery software?
That usually means the partition entry was deleted, but the file data still exists on disk. Recover the files to a different drive right away, then rebuild the partition only after you have verified the data is safe.
Should I recover the partition first or recover the files first?
Recover the files first if the partition table is unstable or you only need specific data. Restore the partition itself only after you have a full copy of the important files, since rebuilding the map can sometimes fail or overwrite metadata.
How do I recover a deleted Boot Camp partition on a Mac?
If Boot Camp was deleted, do not repartition the disk again until you have checked for recoverable data. Use a recovery tool that can inspect both GPT partition tables plus NTFS structures, then copy the Windows files out if they are still intact.
Can Time Machine help after a partition is deleted?
Time Machine can help if the deleted partition held files that were previously backed up. It will not rebuild the missing partition on its own, but it can restore your data to a new volume after the disk layout is fixed.
What if the deleted partition was on an encrypted drive?
Recovery is still possible, but you may need the correct password or recovery key to unlock the data after scanning. If the encryption metadata is damaged, file recovery may still work, but the process can be more limited.
How long does partition recovery on a Mac usually take?
A quick scan can take minutes, while a deep scan on a large drive may take hours. The exact time depends on drive size, connection speed, plus how badly the partition table was damaged.
What are the signs that a deleted partition cannot be recovered at home?
If the drive makes clicking noises, does not mount at all, or shows severe physical errors, software recovery may not be enough. In that case, stop using the disk immediately, then contact a professional data recovery service.
What should I avoid doing after deleting a Mac partition by accident?
Do not reinstall macOS on the same drive, create a new partition, or copy files onto that disk. Any of those actions can overwrite the deleted partition data, which lowers the chance of recovery.
