Mac Recovery Test · August 2026
EaseUS Data Recovery Wizard for Mac: Review 2026
EaseUS makes scanning a drive fairly painless, yet finding files is only half the job. Uneven previews, cluttered results, plus a one-Mac license keep it behind Disk Drill.
5.4 /10
Usable, Yet Hard to Recommend Simple scanning cannot offset inconsistent results or a limited license
Not recommended
EaseUS Data Recovery Wizard for Mac is approachable, but its recovery workflow feels less dependable once scan results get messy. Disk Drill is the better pick for clearer previews, camera-media recovery, disk imaging, plus a license covering up to three devices.
Do not install recovery software on the same disk that lost the files, since new data may overwrite what you hope to restore.
EaseUS Data Recovery Wizard for Mac at a Glance
5.4/10
EaseUS is a desktop app that scans Mac volumes or connected storage for deleted, formatted, lost, or inaccessible files. It can restore common documents, photos, audio, video, archives, plus email data.
Best forMac users with a small, recent deletion that fits inside the 2 GB free allowance
  • Deleted-file plus formatted-drive scans
  • APFS, HFS+, FAT, exFAT, plus NTFS support
  • File filters plus preview window
  • Up to 2 GB of free Mac recovery
  • Bootable-media option in the paid edition
Pricing Free recovery up to 2 GB · Single-Mac license $89.95
Standout featureA genuinely useful 2 GB free recovery limit on macOS
What we liked
  • Easy initial scan setup
  • Broad format support
  • Useful free recovery allowance
What we didn't
  • Messy deep-scan results
  • Uneven previews for difficult files
  • Paid license covers one Mac
How We Evaluated EaseUS Data Recovery Wizard for Mac in 2026
We reviewed the Mac workflow across a deleted APFS file set, a reformatted exFAT memory-card image, plus a mixed document or media collection. The checks covered drive selection, scan behavior, filtering, previews, folder reconstruction, recovery setup, licensing, plus safeguards for unstable storage.
No recovery app can promise a fixed success rate. File condition, overwriting, SSD TRIM, encryption, physical damage, plus prior repair attempts can change the outcome more than the software brand.
When EaseUS Data Recovery Wizard for Mac Is the Wrong Choice
Skip self-service software if a drive clicks, disconnects repeatedly, smells burned, reports the wrong capacity, or no longer appears in Disk Utility. Continued scanning can put mechanically damaged media under more stress.
EaseUS is also a weak fit for multi-computer households or camera users dealing with fragmented video. Disk Drill offers a three-device personal license, byte-to-byte imaging, plus a dedicated camera-recovery mode.
EaseUS Data Recovery Wizard for Mac: How It Scored in 2026
01 Recovery Results
5.7/10
02 Scan Navigation
7.2/10
03 Preview Quality
4.6/10
04 Mac Recovery Tools
5.9/10
05 Cost & Licensing
3.8/10
EaseUS Data Recovery Wizard for Mac Recovery Performance in Detail
Recovery Results
Common files surfaced, though usable output varied
5.7/10
EaseUS found familiar JPG, PNG, PDF, MOV, ZIP, plus Office files across deleted-file or formatted-volume scenarios. The trouble appeared after the scan. Some signature-based results lost their original names or folders, leaving long batches of generic files to sort manually.
Recently deleted material produced the cleanest results. Older data from reformatted media was less orderly, especially where file fragments were involved. That is normal to a point, but EaseUS did not give us enough context to separate promising files from weak candidates quickly.
What we liked
  • Finds many common photo, video, document formats
  • Supports APFS, HFS+, exFAT, FAT, plus NTFS media
  • Can scan external drives, memory cards, USB storage
  • Recovered files can be saved to a separate destination
What we didn't
  • Deep-scan results can lose useful folder structure
  • Generic file names make large recoveries tedious
  • Detection does not guarantee that a file will open correctly
Scan Navigation
The strongest part of the EaseUS experience
7.2/10
The main screen keeps the first decision simple. Pick a volume, start the search, then inspect files while the scan continues. Filters for file type, size, date, or status reduce some of the clutter.
The interface becomes less helpful when a scan returns thousands of entries. Existing files can sit beside deleted or reconstructed items, while duplicate-looking results require repeated preview checks. EaseUS is easy to start, but slower to audit.
What we liked
  • Clear drive-selection screen
  • Results appear before a scan finishes
  • Useful type, date, plus size filters
  • Search works well when the original name survives
What we didn't
  • Large result sets become repetitive
  • Recovered, deleted, plus existing files can look too similar
  • Important status details are easy to miss
Preview Quality
Too uncertain for the step that matters most
4.6/10
A working preview is one of the safest signals available before paying or restoring files. EaseUS displayed plenty of ordinary images or documents, yet larger videos, damaged media, plus less common formats were more inconsistent.
A blank preview does not always mean recovery is impossible. Still, it leaves the buyer guessing. Disk Drill presents previews, recovery-chance indicators, plus result groupings in a way that makes the decision easier before checkout.
What we liked
  • Photo thumbnails speed up visual searches
  • Many standard documents can be checked in-app
  • Previewing is available before a full paid recovery
What we didn't
  • Large video previews can be unreliable
  • Blank previews leave recovery prospects unclear
  • No preview can make a paid upgrade feel like a gamble
Mac Recovery Tools
Solid basics without the same depth as Disk Drill
5.9/10
EaseUS covers routine Mac recovery from internal volumes, external disks, memory cards, plus Time Machine storage. It also supports bootable recovery media for cases where macOS will not start, though setup requires extra steps.
Disk Drill offers a broader recovery workspace. Its byte-to-byte backup can capture a questionable device before repeated scans, while Advanced Camera Recovery targets fragmented video from cameras. Those tools matter when an SD card or aging drive may be getting worse.
What we liked
  • Works with APFS or HFS+ volumes
  • Supports removable media attached to a Mac
  • Includes filtering plus cloud-save options
  • Bootable recovery is available in the paid edition
What we didn't
  • Fewer useful diagnostic details around individual files
  • Disk imaging is not as central to the workflow
  • Camera-video recovery feels less specialized
Cost & Licensing
A narrow license at nearly the same entry price
3.8/10
The free Mac edition can recover up to 2 GB, which is useful for a small folder or a handful of photos. EaseUS lists its single-Mac license at $89.95, with lifetime upgrades included on the offer reviewed.
Disk Drill PRO is listed at $89 per year for one user on up to three devices, covering macOS plus Windows. The annual renewal is a caveat, though the broader device allowance gives households with several computers more room.
What we liked
  • Free edition includes up to 2 GB of recovery
  • Single-Mac offer includes lifetime upgrades
  • No need to pay merely to start a scan
What we didn't
  • $89.95 license covers only one Mac
  • Checkout extras can distract from the base purchase
  • Poor value if you need recovery on several computers
Free $0 Recover up to 2 GB on Mac
Single Mac $89.95 One license with lifetime upgrades included
EaseUS Data Recovery Wizard for Mac vs Disk Drill: Head to Head
We compared both Mac apps through the same basic workflow: identify storage, scan deleted or formatted media, inspect previews, then prepare files for recovery. Licensing plus protective tools were scored separately.
Metric EaseUS Data Recovery Wizard for Mac Disk Drill
Result Organization Useful filters, cluttered deep-scan output Clearer categories plus recovery-chance labels
Preview Workflow Good for basic photos or documents Unlimited Mac preview with stronger file triage
Camera Media Recovery Standard memory-card scanning Dedicated Advanced Camera Recovery module
Drive Imaging Less prominent in the recovery process Built-in byte-to-byte backup workflow
Free Mac Use Up to 2 GB of file recovery Scan plus preview, normal recovery requires PRO
Personal License $89.95 for one Mac $89/year for up to three Mac or Windows devices
Latest Mac Toolset Reviewed General-purpose recovery suite Version 6.3 with camera plus encrypted-volume improvements
Overall Score 5.4 / 10 8.7 / 10
Use Disk Drill Instead of EaseUS on Mac
Disk Drill costs about the same at entry, yet its three-device license, disk imaging, clearer result grading, plus camera-focused recovery make it the more practical choice.
Disk Drill
A better-organized Mac recovery workspace
8.7/10
Disk Drill is our preferred alternative because it makes the pre-recovery decision less murky. You can scan or preview files before purchasing, inspect estimated recovery chances, then save a byte-to-byte image when the source device seems unstable.
Its Advanced Camera Recovery module is particularly useful for SD cards containing fragmented camera footage. The main drawback on Mac is straightforward: ordinary file recovery requires PRO, even though scanning plus previews are free.
Why We Recommend It
  • Cleaner result grouping plus recovery-chance labels
  • Byte-to-byte backups help reduce repeated work on failing media
  • Advanced Camera Recovery targets fragmented photo or video files
  • One personal license supports up to three devices
  • Works on macOS plus Windows
Caveats
  • Standard recovery is not free on Mac
  • $89 annual plan renews unless canceled
  • Activated digital purchases have a restrictive refund policy
Basic $0 Unlimited scanning plus preview on Mac
PRO $89/year Unlimited recovery for one user on up to three devices
Disk Drill Review ↗ Download Disk Drill
What Mac Users Report About EaseUS Data Recovery Wizard
The reviewer said EaseUS recovered needed files after an old backup drive failed, turning a stressful client-file request into a successful recovery.
Thegslice · Mac App Store
This user reported that the app found nothing useful on either a memory card or Mac drive. They also felt the recovery instructions were outdated, then sought a refund.
samuelbirdsong · Mac App Store
A reviewer said accidentally deleted files were restored fairly quickly, with the app recovering everything they needed.
KrystineN · Mac App Store
The user described the scan as little more than Finder in their case, saying it failed to detect Trash files deleted only minutes earlier. They also criticized support.
ChrisA_NJ · Mac App Store
Should You Use EaseUS Data Recovery Wizard for Mac?
EaseUS Data Recovery Wizard for Mac works best for a recent, modest deletion where the free 2 GB allowance covers everything. It falls short once results lose their names, previews stop helping, or several computers need coverage.
Most Mac users should scan the affected device with Disk Drill first. Its preview tools, disk imaging, camera recovery, plus broader personal license make it easier to judge a recovery before committing money.
Stop using the affected disk, connect it as secondary storage if possible, then confirm several important files through preview before paying for any recovery app.
EaseUS Data Recovery Wizard for Mac Questions, Answered
Is EaseUS Data Recovery Wizard for Mac worth buying in 2026?
It can help in simple file loss cases, but it feels overpriced for what it does. If you only need occasional recovery after a mistaken delete, you may find cheaper or more dependable options.
How well does EaseUS Data Recovery Wizard for Mac work with APFS drives?
It usually handles basic APFS recovery, but results can be inconsistent on heavily used drives. If the disk has been overwritten, expectations should stay low.
Why is EaseUS Data Recovery Wizard for Mac so slow during scans?
Deep scans can take a long time, especially on large SSDs or external drives with lots of files. The slowdown is common enough that it can make the trial feel more frustrating than useful.
Does EaseUS Data Recovery Wizard for Mac recover data from Time Machine backups?
It can sometimes detect backup files, but it is not a clean fix for damaged Time Machine storage. For Time Machine issues, Apple’s built-in restore options usually make more sense first.
What is the biggest problem with EaseUS Data Recovery Wizard for Mac?
The biggest complaint is the gap between the marketing promise plus real recovery results. It often finds files, then leaves you guessing whether the recovered versions will actually open.
Is the free version of EaseUS Data Recovery Wizard for Mac useful?
Only for previewing what might be recoverable. The recovery limit is tight enough that many people hit the paywall before they can finish a real test.
Can EaseUS Data Recovery Wizard for Mac recover emptied Trash files?
Sometimes, yes, if the data has not been overwritten yet. If you keep using the Mac after deletion, the odds drop fast.
How does EaseUS Data Recovery Wizard for Mac compare with Disk Drill?
Disk Drill usually feels more polished, while EaseUS often feels more dated. If you want a smoother interface plus clearer scanning behavior, Disk Drill tends to be the stronger pick.
Is EaseUS Data Recovery Wizard for Mac safe to install?
It is a legitimate app, but you should still download it only from the official site. Like any recovery tool, give it Full Disk Access only when you need it, then remove permissions later if you want to keep your Mac tighter.
Why does EaseUS Data Recovery Wizard for Mac show files that will not open?
That happens when the file structure is damaged even though the name or preview is still visible. It looks promising at first, then recovery often ends in broken documents or unreadable media.
Can EaseUS Data Recovery Wizard for Mac recover data from a formatted external drive?
It may recover some files if the format was quick plus the drive has not been reused much. For a drive that has been written to again, results can become very poor.
What file types does EaseUS Data Recovery Wizard for Mac usually recover best?
Simple documents, photos, plus some video files tend to do better than fragmented project files or databases. Complex app data is much more hit or miss.
Does EaseUS Data Recovery Wizard for Mac work on Apple silicon Macs?
Yes, but performance can still vary depending on the disk being scanned. Native support does not fix the core problem that recovery quality is often unpredictable.
How much does EaseUS Data Recovery Wizard for Mac cost in 2026?
Pricing changes often, yet it usually sits in a range that feels high for a one-time emergency tool. If you only need one recovery, the value can be hard to justify.
Is there a better alternative to EaseUS Data Recovery Wizard for Mac for lost photos?
If your main goal is photo recovery, a tool with stronger previews plus easier filtering may serve you better. EaseUS can work, but it is rarely the first choice for speed or confidence.
What should I do if EaseUS Data Recovery Wizard for Mac cannot find my deleted files?
Stop using the drive right away, then try another recovery tool or a professional service. Every extra write lowers the chance of getting the file back cleanly.
Can EaseUS Data Recovery Wizard for Mac recover data from a crashed MacBook?
It can sometimes help if the storage is still readable in recovery mode or through an external enclosure. If the SSD has physical failure, software recovery is usually the wrong path.
Should I use EaseUS Data Recovery Wizard for Mac or Apple Recovery first?
Start with Apple’s built-in options if the issue is a recent deletion, backup restore, or a system problem. EaseUS is more of a last resort when normal recovery steps fail.
