Compatibility Check · August 2026
Lazesoft Mac Data Recovery: Review 2026
Lazesoft’s Mac utility costs nothing, though that advantage fades fast on a current Mac. Its old system support, missing APFS recovery, plus uneven results make it tough to recommend.
3.2 /10
Too Old for a Modern Mac Free recovery cannot offset obsolete compatibility
Not recommended
Lazesoft Mac Data Recovery is free but effectively frozen in an earlier Mac era. It lacks APFS support, officially targets old Intel Macs, plus performs poorly with several common file formats. Download Disk Drill instead for current macOS support, broader scanning, byte-to-byte backups, plus useful previews before payment.
Do not install or run recovery software on the same drive that contains your missing files, since new writes may overwrite recoverable data.
Lazesoft Mac Data Recovery at a Glance
3.2/10
Lazesoft Mac Data Recovery is a free utility for restoring deleted files from older Mac-compatible storage. It is mainly relevant to legacy Intel Macs plus HFS-era external media.
Best forOwners of an older Intel Mac testing a noncritical HFS+ external disk
  • Quick file scan
  • Partition recovery mode
  • HFS plus HFS+ support
  • Image preview during scanning
  • Unlimited free personal recovery
Pricing Mac freeware $0 · Unlimited recovery on supported legacy systems
Standout featureUnlimited recovery without a payment gate
  • Completely free
  • Small, simple application
  • Can recover from some older external volumes
  • No APFS support
  • Obsolete macOS compatibility
  • Weak modern photo plus video recovery
How Lazesoft Mac Data Recovery Scored in Our 2026 Review
01 Modern Mac Compatibility
1.5/10
02 Recovery Results
2.8/10
03 Scan Workflow
3.5/10
04 File System Coverage
2.2/10
05 Cost & Access
8.8/10
How We Evaluated Lazesoft Mac Data Recovery for This 2026 Review
We audited the current download requirements, supported file systems, release history, scan controls, preview options, pricing, plus published recovery tests. The comparison also checked whether each app could address common 2026 Mac cases such as APFS storage, Apple silicon hardware, recent camera files, plus unstable external disks.
Scores place extra weight on compatibility plus recoverable output. A free license helped Lazesoft’s value score, but it could not compensate for missing APFS support or the lack of dependable operation on current macOS releases.
When Lazesoft Mac Data Recovery Is the Wrong Tool
Avoid Lazesoft for an internal SSD from a current Mac, an APFS-formatted external drive, or files from a recent mirrorless camera. It is also a poor choice when preserving filenames plus folder paths matters.
Skip DIY software entirely if the drive clicks, disappears repeatedly, smells burned, or spins down during access. Power it off. A recovery lab has better odds than repeated home scans on physically failing hardware.
Lazesoft Mac Data Recovery Performance by Category
A poor match for current Apple hardware
1.5/10
This is the deal breaker. Lazesoft’s published requirements refer to Intel Macs running OS X 10.5 or later, while the old Mac edition has not kept pace with Apple’s platform changes. Its last substantial release belongs to the mid-2010s.
That leaves current macOS versions, Apple silicon, modern security controls, plus today’s internal storage layouts outside any dependable support path. Even if the installer opens on an intermediate macOS release, opening is not the same as reliable recovery.
  • May remain usable on an old Intel Mac
  • Small installer footprint
  • Native-looking workflow for its original OS X era
  • No dependable current-macOS support
  • No native Apple silicon release
  • Official requirements are badly outdated
Recovery Results
Mixed output with weak modern-format handling
2.8/10
Published recovery testing shows Lazesoft doing best with simpler NTFS cases, despite being sold as a Mac utility. HFS+ results were inconsistent, while recovered FAT data could lose original names or folder structure.
Signature recovery is another weak spot. Older JPG or document files have a better chance than recent camera RAW formats or fragmented video. Finding thousands of items is not useful if the important MOV, MP4, or CR3 files return damaged, unnamed, or not at all.
  • Can recover some recently deleted files
  • Allows recovery before a scan fully finishes
  • Basic file search helps narrow large result lists
  • Weak results outside favorable NTFS cases
  • Modern photo plus video signatures are limited
  • Folder structure may not survive recovery
Scan Workflow
Simple in places, awkward where it counts
3.5/10
The wizard gives users a clear sequence: choose a mode, select a device, scan, mark files, then save them elsewhere. The trouble is that Lazesoft makes the user choose between recovery methods without much useful guidance.
Full signature scanning may require manual setup. Preview support leans heavily toward images, result browsing slows with very large folders, plus there is no polished system for managing repeated scans. Disk Drill’s unified scan is less fiddly for someone already stressed about missing files.
  • Straightforward step-by-step wizard
  • Scanning progress is easy to follow
  • Files can be saved to a separate destination
  • Scan method must be chosen manually
  • Dated result browser becomes cumbersome
  • Preview support is narrow
Old standards covered, APFS left out
2.2/10
Lazesoft lists support for HFS, HFS+, HFSX, FAT12/16/32, NTFS, plus NTFS5. That list made sense when the app was released, but it misses APFS, the standard file system used by current Macs.
No APFS support rules out many internal Mac SSD cases immediately. The Mac app is better viewed as a free utility for older external disks than as a general recovery solution for a 2026 Mac.
  • Covers HFS plus HFS+ volumes
  • Reads several older Windows file systems
  • Useful for a narrow set of legacy external disks
  • No APFS recovery
  • Limited relevance for current internal Mac storage
  • No modern RAID reconstruction tools
Cost & Access
Truly free, though usefulness is narrow
8.8/10
Lazesoft Mac Data Recovery costs $0 for personal recovery. There is no recovery quota, locked save button, or paid Mac tier to unlock. That is unusually generous.
Free access only matters if the app supports the Mac, file system, plus file type involved. For an old HFS+ external drive connected to an older Intel Mac, the price is compelling. For an APFS SSD or a new MacBook, paying for maintained software is the more practical route.
  • Unlimited personal recovery at $0
  • No subscription
  • No payment wall after a long scan
  • Good option for low-stakes legacy-media experiments
  • No paid modern Mac edition to upgrade to
  • Free access does not solve compatibility gaps
Mac Freeware $0 Unlimited personal recovery on supported legacy setups
Lazesoft Mac Data Recovery vs Disk Drill — Head to Head
We compared both Mac utilities by current system support, storage coverage, recovery workflow, plus the safeguards available before files are copied. Lazesoft wins on price, while Disk Drill is the more usable choice for current hardware.
Metric Lazesoft Mac Data Recovery Disk Drill
Current macOS support No dependable support for current releases Disk Drill 6 supports macOS 10.15 through 26.x
Apple silicon support Intel-era application Supports M-series Macs
Mac file systems HFS, HFS+, HFSX APFS, HFS, HFS+ plus other major formats
File reconstruction Limited support for newer signatures Reconstructs 400+ file types
Drive imaging No polished byte-to-byte imaging workflow Byte-to-byte backup included
Scan results Basic search, sorting plus limited previews Filters, previews plus recovery-chance estimates
Personal license $0 unlimited recovery on supported systems $89/year or $149 lifetime, free scan plus preview on Mac
Overall score 3.2 / 10 9.0 / 10
What to Use Instead
Use Disk Drill if your files were lost from a current Mac, APFS volume, camera card, external drive, or disk image. It gives you a realistic preview of the result before asking for payment.
Disk Drill for Mac
A maintained recovery app for current Macs
9.0/10
Disk Drill 6 is the better fit for a Mac in 2026. It supports Apple silicon, APFS, current macOS releases, external media, disk images, mobile devices, plus multiple RAID layouts. Its free Mac version scans drives plus previews recoverable files before you decide whether a license is justified.
The byte-to-byte backup tool is especially useful when a drive may be unstable. Rather than repeatedly scanning stressed hardware, you can create an image on a healthy disk, then perform recovery work from that copy. Disk Drill is not free for Mac recovery, though its broader compatibility makes the cost easier to defend.
Why We Recommend It
  • Supports current macOS plus M-series Macs
  • Recovers from APFS, HFS+, FAT, exFAT, NTFS plus other formats
  • Free scanning plus file preview on Mac
  • Byte-to-byte disk images reduce repeated access to weak media
  • Clear filters plus recovery-chance estimates
Caveats
  • Mac file recovery requires a paid license
  • Annual plan costs $89
  • No consumer app can repair physical drive damage
Basic for Mac $0 Scan plus preview only — pay to recover
PRO Annual $89/year Unlimited personal recovery for one user
PRO Lifetime $149 One-time license for ongoing personal use
Disk Drill Review ↗ Visit Disk Drill Help Center
What Users Report About Lazesoft Plus Disk Drill
A Mac user said Lazesoft had worked well before, but the app would not support the Catalina system needed for a later recovery job.
Reddit user · r/MacOS
One Lazesoft user reported that the app failed to notice a USB stick connected after launch. Restarting the utility made the device appear.
Mac Informer reviewer · Mac Informer
The Disk Drill review author recovered photos from an inaccessible camera card after other tools failed to see it. Advanced camera recovery was important for the fragmented videos in that case.
Another Disk Drill customer said the scan appeared promising before purchase, yet the needed files could not be restored. The user was also unhappy with the support response.
Should You Use Lazesoft Mac Data Recovery in 2026?
Lazesoft Mac Data Recovery still has one real attraction: unlimited recovery for $0. An old Intel Mac paired with a low-value HFS+ disk is about the only setup where we would consider it.
Everyone using a current Mac, APFS storage, recent camera formats, or important work should skip it. Disk Drill offers the maintained macOS support, broader file reconstruction, safer imaging tools, plus free previews that Lazesoft lacks.
Stop using the affected drive, create a byte-to-byte image if the hardware is unstable, then confirm that your key files preview correctly before buying recovery software.
Lazesoft Mac Data Recovery Questions, Answered
Is Lazesoft Mac Data Recovery worth using in 2026 for a lost file on a Mac?
Usually no, if you need a modern recovery tool with smooth Mac support. The interface feels dated, the workflow can be clunky, plus newer Macs often need a better fit for APFS plus Apple Silicon.
What is the biggest problem with Lazesoft Mac Data Recovery on newer Macs?
Compatibility is the main pain point. Users on current macOS versions can run into limited support, slower scans, or features that do not behave well on modern file systems.
Can Lazesoft Mac Data Recovery recover files from an external SSD on Mac?
Sometimes, but results can be inconsistent. It may work on simple cases, yet external SSD recovery is exactly where more current tools tend to do better.
Does Lazesoft Mac Data Recovery work with APFS volumes?
That is where many users start having trouble. APFS support is a key expectation on Mac, yet this tool is not a strong choice if your drive was formatted with Apple’s newer file system.
Is there a free version of Lazesoft Mac Data Recovery?
A free option may exist for limited recovery, but it is not generous. In practice, you can hit a wall quickly, then get pushed toward payment before you know whether it will recover the file you need.
How does Lazesoft Mac Data Recovery compare with Disk Drill or R-Studio?
It usually loses on polish, speed, plus recovery depth. Disk Drill feels more Mac friendly, while R-Studio is often better for serious recovery jobs or damaged drives.
Why does Lazesoft Mac Data Recovery feel outdated?
The design, navigation, plus overall workflow feel behind current Mac software. That matters because recovery is stressful, so a confusing interface makes a bad situation worse.
Can Lazesoft Mac Data Recovery recover photos from a formatted Mac drive?
It may recover some files, but formatted-drive recovery is not where it shines. If the drive was recently erased, a stronger recovery app or a professional service may be a smarter first move.
Does Lazesoft Mac Data Recovery support Apple Silicon Macs like M1, M2, or M3?
Support is not something I would trust blindly here. On Apple Silicon Macs, users should verify current compatibility before paying, since older recovery software often lags behind Apple's hardware changes.
What should I do if Lazesoft Mac Data Recovery finds files but cannot restore them?
Try a different recovery tool right away, since preview results do not always mean successful recovery. Also avoid saving anything new to that drive, because every write lowers your odds.
Is Lazesoft Mac Data Recovery safe to install on a Mac?
It is not known as malware, but safety is more than just virus-free. You still want to download from the official site, then be careful not to install it onto the same drive you are trying to recover.
Does Lazesoft Mac Data Recovery work well for corrupted hard drives?
Not reliably. Corrupted drives are a harder case, plus this is where weaker tools tend to stall, freeze, or miss key data.
What file types can Lazesoft Mac Data Recovery restore on Mac?
It claims support for common file types like documents, photos, plus videos, but actual results depend on the condition of the disk. If the file system is badly damaged, the file type list matters less than scan quality.
How long does a scan take in Lazesoft Mac Data Recovery?
It can take a while, especially on large drives or damaged volumes. Slow scans are a common complaint, so if you need quick results, this is not the most efficient option.
Can I use Lazesoft Mac Data Recovery after emptying the Trash on Mac?
Yes, but only if the deleted data has not been overwritten. Once the drive keeps getting used, the chances drop fast, so stop normal activity on that Mac first.
What are the main reasons people complain about Lazesoft Mac Data Recovery?
The biggest complaints are weak modern Mac support, awkward usability, plus inconsistent recovery results. People often expect a straightforward rescue tool, then get a slow, frustrating process instead.
Is Lazesoft Mac Data Recovery good for Time Machine backup recovery?
It is not the first tool I would pick. If your data exists in Time Machine, Apple’s built-in recovery path is usually simpler, more dependable, plus less risky.
What is a better alternative to Lazesoft Mac Data Recovery for Mac users in 2026?
Disk Drill is a common pick for easier Mac recovery, while R-Studio is better when the situation is technical. If the drive is physically failing, a professional data recovery lab may be the only sensible alternative.
Can Lazesoft Mac Data Recovery recover data from a dead Mac that will not boot?
Only if you can access the storage separately, such as by connecting the drive to another Mac or enclosure. If the Mac is dead because the drive is failing, software alone may not be enough.
Should I pay for Lazesoft Mac Data Recovery before testing it?
No, not if you have other options. First verify that it can see your drive, preview the right files, then compare it with newer recovery tools before spending money.
